World’s First Mini Hyper-Hemispherical FOV 3D Lidar For Robots Launched
Hesai Technology, a global leader in lidar technology, launched its JT Series of mini hemispherical 3D lidars at the recent CES 2025 in Las Vegas. Designed specifically for robotics applications, the JT series includes the JT16 (16 channels) and the JT128 (128 channels). The JT128 features the world’s widest hyper-hemispherical field of view (FOV) at 360° x 187°, powered by Hesai’s proprietary technology. Compact and lightweight, the miniature JT series ensures that the lidar is easily installed and concealed in diverse robotic applications.
The JT series supports high-quality resolution up to 256 channels, and offers ultra-clear 3D environmental perception with a coverage area equivalent to two football fields. The JT series also has a minimum detection distance of 0 meters, which ensures there are no blind spots in close-range perception and ensures the application’s ability to operate safely in different scenarios.
The Hesai JT series leads the robotics lidar market in technological innovation and cost effectiveness, enabling high-precision 3D lidar to empower various robotic applications such as AGVs/AMRs as well as stationary applications.
Seamless Integration
The JT series is compact and lightweight with a minimum bottom diameter of only 55 mm. The diameter is approximately 30% smaller compared to similar products, and the volume has been reduced by 70% compared to similar products (1). With its miniature size, JT can be flexibly installed on various types of robots and industrial equipment. Through concealed embedded installation, the height of its surface window will not exceed 30 mm.
The World’s First Hyper-Hemispherical FOV for Robots
The JT series adopts a fully rotational horizontal scanning method, easily obtaining a 360° horizontal field-of-view (FOV). Through innovative optical module design, the vertical FOV is 187°.
The JT series’ hyper-hemispherical FOV is 60% larger that of traditional 3D lidar, providing an exceptional perception range for robots and industrial equipment, while taking into account ground detection and vertical environmental perception, which helps to improve positioning accuracy and obstacle recognition.
“As the next exciting product platform in our industry-leading lidar portfolio, the JT series is yet another example of Hesai innovation,” says David Li, Co-founder and CEO of Hesai Technology. “Its compact design, unmatched precision and versatility make it an ideal solution for a wide range of robotic applications. The JT series is a testament to Hesai’s commitment to pushing technological boundaries and delivering solutions that drive the future of mobility and automation.”
For more information: www.hesaitech.com
