Titan Tool Supply Introduces Industrial Videoscope Series
Titan Tool Supply has announced the global market introduction of the TVM Series of accurate, cost-effective, handheld industrial videoscopes.
Offered in four standard models, TVM Series industrial videoscopes provide high-quality, speedy remote visual inspection and diagnostic capabilities across a diverse array of applications. All TVM Series models feature a 4.3-inch monitor and user-friendly button technology. Individual models are further offered with a choice of either a 4.5 mm or 6.2 mm diameter cable, and either a 1.5 m or 3 m working cable length. All TVM Series cabling further includes a Tungsten braided sleeving for added durability and reliability within dirty or harsh industrial applications.
The mechanical joystick that is incorporated into each Model TVM Series unit is expressly designed for ease of operator control. It offers full-360° four-way articulation, as well as operator-applied and guided input capabilities, for smooth, accurate, and direct control of both the camera and articulating camera tip during remote visual inspections. The camera can also accurately hold its designated position after joystick pressure is released. Design of the articulating camera tip incorporates a series of high-intensity LEDs with five-step intensity control. The LEDs allow the joystick to guide the videoscope more accurately and easily through narrow bores, channels, curves, and other complex geometries, and including in areas where diminished lighting conditions may otherwise be of concern.
Typical applications for the TVM Series include aviation MRO, automotive service inspections, casting inspections, cavity inspections, diesel and gasoline engine repair, locomotive maintenance, ship maintenance, industrial machinery and equipment monitoring, manufacturing quality control, or virtually any other industrial application requiring accurate, cost-effective remote visual inspection.
For more information www.titantoolsupply.com
