Shop Floor CNC CMM Delivers Next-Level Accuracy and Performance for Larger Parts
Mitutoyo America Corporation has announced the launch of the MiSTAR 575 Shop Floor CNC Coordinate Measuring Machine (CMM). Building upon the success of MiSTAR 555, the MiSTAR 575 takes shop-floor performance, accuracy, and measuring range to new heights, offering unparalleled capabilities for a wide range of applications.
Designed to measure small to medium-sized workpieces, the MiSTAR 575 delivers the same high standards of accuracy, repeatability, speed, and environmental resistance that Mitutoyo is known for. With its expanded measuring range, the MiSTAR 575 is optimized for larger parts while maintaining exceptional performance in demanding environments.
Advantages of MiSTAR 575 To MiSTAR 555:
Expanded Measuring Range: Supports a broader range of workpieces, ideal for larger parts and more complex applications.
Exceptional Accuracy: Delivers the precision and reliability Mitutoyo is renowned for.
Optimized for Larger Parts: Perfect for applications requiring higher measurement capabilities.
Coolant/Environmental Resistance: The MiSTAR 575 maintains the same resistance to shop-floor conditions, including coolant exposure.
Temperature Compensation: Ensures stable and accurate measurements, even with fluctuating temperatures.
With environment-resistant ABSOLUTE scale and revamped body structure, the MiSTAR Series is a contamination-resistant coordinate measuring machine. Highly reliable as a result of real-time temperature compensation technology that guarantees accuracy over a wide temperature range, it delivers a length measurement error of MPE 2.2 + 3L/1000 ÎĽm. The MiSTAR Series can be installed and operated next to machine tools on production lines.
The MiSTAR 575 offers the perfect combination of extended range and high precision, making it an ideal solution for both the manufacturing floor and the quality inspection room. Whether looking to increase throughput or require a CMM with larger measurement capabilities, the MiSTAR 575 will help elevate the production inspection process.
