RUN Brings Metrology-Grade Measurement Directly to the Shopfloor
As manufacturing environments continue to evolve toward faster cycles, higher complexity, and greater automation, the role of dimensional inspection is shifting decisively onto the production floor. Ready’s RUN series of coordinate measuring machines has been developed specifically to meet these demands, delivering metrology-grade accuracy in a robust, production-ready format.
Designed for direct deployment in manufacturing environments, RUN combines precision, durability, and operational simplicity to enable rapid inspection, real-time feedback, and process control at every stage of production. By bringing high-quality measurement closer to the process, RUN helps manufacturers shorten response times and improve overall production efficiency.
Measurement Simplified for Production
RUN systems were developed with a clear objective: to make measurement simple, fast, and reliable in real-world shopfloor conditions. Seamless integration into production workflows allows inspection to take place without disrupting manufacturing operations.
At the core of the system are linear motors that provide smooth, maintenance-free motion. The absence of air supply and lubrication requirements eliminates common sources of downtime, while ensuring long-term stability and reliability even in demanding industrial environments.
Ease of Use Built In
Operator usability is central to the RUN design philosophy. The Easy Runner interface allows inspection programs to be loaded and executed with a single touch, minimizing training requirements and reducing the risk of operator error. A moving table design, complemented by an optional clamping kit, enables fast, ergonomic part handling for both manual and automated workflows.
For automated production lines, RUN’s moving table architecture simplifies robot integration. By keeping both the portal and measuring head outside the robot motion envelope. Switching between part types is equally straightforward. Operators can scan a barcode to load a new inspection program, after which measurement and reporting are carried out automatically – allowing changeovers to take place in seconds rather than minutes.
Precision That Endures on the Shopfloor
To ensure consistent performance over time, RUN systems incorporate advanced features designed to maintain accuracy and repeatability under shopfloor conditions. These include an automatic stylus cleaning unit and an active anti-vibration granite base with pneumatic dampers.
Together, these elements protect measurement integrity against contamination, vibration, and environmental disturbances, delivering stable, reliable results where traditional metrology systems may struggle.
From Inspection to Process Optimization
RUN is designed for both end-of-line inspection and in-process verification, providing immediate measurement feedback that enables manufacturers to detect deviations early, reduce scrap, and shorten setup times.
Integrated CAD import and GD&T analysis offer full visibility into part geometry and compliance with design specifications. By transforming raw measurement data into actionable insight, RUN supports continuous process improvement and more informed production decisions.
A Smarter Approach to Coordinate Measurement
With the RUN series, Ready redefines the role of the coordinate measuring machine in modern manufacturing. Rather than serving solely as a back-end validation tool, RUN functions as an active production resource—supporting quality control, process optimization, and operational efficiency directly on the shopfloor.
By combining precision engineering with practical, production-oriented design, RUN demonstrates how metrology can become a strategic driver of manufacturing performance.
For more information: www.readymetrology.com
