Role of Edge Computing in The Smart Factory
According to Google Trends data, worldwide searches for âedge computingâ have increased tenfold in the last five years. Google alone boasts 340 million search results for the phrase â hardly simple revision for those curious about the technology. Among the noise â and the varying definitions of edge computing â the technology has become somewhat misunderstood. Martyn Williams, Managing Director of industrial software expert, COPA-DATA UK examines the role of edge computing in smart factories.
Edge computing describes a distributed version of computation that brings data analysis closer to the source of data. In a factory setting, this could see data processing take place at the machine level. Unlike centralized models, where information would be sent to a data center or the cloud, edge computing allows data capture, analysis, and action to be performed on the edge of a process â hence the name.
Despite its capabilities, edge computing is not a replacement for centralized data storage methods, or an alternative to other data processing and management technologies. In fact, these architectures must work together to be truly beneficial.
So, are edge devices just a new brand of the same technology? Not exactly.
Latency Reduction
Edge devices are unique in the sense that they provide first-stage processing of data before sending this information elsewhere. Edge devices can also act on this data within the realms of the device itself, thanks to their intelligent capabilities. This can be achieved using forms of artificial intelligence (AI) and machine learning to help in decision making.
Because everything is taking place on the device, this method can significantly reduce latency, removing the time spent between sharing this information with distant data centers and awaiting feedback.
In practice, this could help a manufacturer to avoid critical failures and downtime. In an oil and gas application, for example, an edge device could detect dangerously high pressure in pipes. Rather than waiting for this data to be processed elsewhere and sent back to a site manager, the device could trigger instant shut offs or adaptations to avoid a disaster. Similarly, this same method can be used to make automated adjustments to a process to improve the outcome â this could be related to energy efficiency, accuracy or productivity.
The ability to effect change based on real-time data does exist in current software platforms. COPA-DATAâs zenon, for instance, can be deployed across an entire facility to monitor operations. Compatible with most communication protocols, the software can pull data from a variety of equipment, sensors and vertical systems to provide operators with a real-time dashboard of facility-wide insights. Like our aforementioned example, this can alert users to disruptions in production and highlight potential problems.
Streamlining Data
IIoT technologies have resulted in a huge increase in data across the industry. Today, it is not unusual for manufacturers to produce data on everything from energy efficiency and productivity, right through to operational insights and predictive maintenance. In fact, research suggests that the average smart factory produces five petabytes of data every week â thatâs five million gigabytes, or the equivalent of more than 300,000 16 gigabyte iPhones.
Manufacturingâs big data has quickly become colossal, and edge computing provides a way to reduce the volume of data being sent to a centralized space.
For industries that rely on data integrity for compliance, deploying edge computing to manage some data analysis can become a vital part of a data management strategy. Pharmaceutical manufacturers, for example, must comply with the Food and Drug Administration (FDA) 21 CFR part 11 regulation. This standard applies to drug manufacturers and bio tech companies and requires these organizations to keep an accurate audit trail and electronic records. EU GMP Annex 11 is the European equivalent.
In these industries, on-edge analysis of some data can reduce the volume of information being sent to the cloud or data center. Crucially, this ensures that time sensitive data is not lost in the flood of information.
Scaling The Edge
While some processes do benefit from instant data analysis, smart factories cannot work in silos. The rise of the edge does not mark the downfall of other data management technologies. In fact, it reinforces their necessity.
Software platforms that can communicate with edge devices are essential for making edge technology scalable. Moreover, platforms that can collect, analyze, and visualize data from the edge â while compiling this with a variety of other types of equipment â are essential for constructing a holistic view of a factoryâs operations.
Realistically, most manufacturing facilities are not in a position for the widespread deployment of edge devices, or edge platforms to converge these technologies. Instead, manufacturers need scalable options in their journey to digitalization â and independent software can be the glue that makes this possible.
For more information: www.copadata.com
