Protective Water Cooled Camera Enclosure Launched
autoVimation, a pioneer in the design and production of industrial-grade protective camera enclosures, has introduced its first protective camera enclosure with an integrated water-cooling circuit.
The Elephant series enclosure is suited for camera cross sections up to 100 mm x 100 mm. Cooling channels run through all sides of the casing, including the front and back lids, their total length almost 7 times the length of the enclosure.
The extraordinarily effective temperature control allows for camera operation at ambient temperatures from -40 °C to 200 °C. The accompanying heat exchanger can be operated up to 20m away. It features a pump, radiator and monitoring functions for the camera temperature, volume flow and fan.
Available accessories include various viewing windows and the powerful Meganova LED ring light. The manufacturer also offers an assembly kit with lightweight, robust dovetail profiles for the construction of inspection systems.
For more information: www.autovimation.com
