Portable Arm Scanner Supplies a Soft Touch To Aircraft Seating Inspection
Geven, renowned supplier of aircraft seating has enhanced it control and assembly production phases by opting for a Kreon Ace measuring arm complete with 3D laser scanner. In its search for solutions to speed up controls, Geven turned to Kreon with the performance of the products and the skill of the Kreon technicians decisive in its choice.
In the huge workshops of Geven, the assembly lines for aircraft seats bring together numerous parts from produced using various manufacturing techniques. Certain parameters must therefore be taken into account when choosing the 3D measuring device: reflective metal structures, large composite parts and soft parts such as foams and fabrics.
The Ace measuring arm answered all these measurement problems due to its Skyline Wide 3D scanner. In particular, it makes it possible to precisely inspect soft surfaces without contact and therefore without deformation. The assembled seat is checked quickly, thanks to the Skyline Wide’s 200 mm laser line, to ensure flawless operation and perceived quality.
The Kreon Ace 7-axis 2.5m measuring arm with Skyline Wide scanner is used for the following applications:
➤ Control of tools for plastic and composite parts
➤ Inspection of the first injected plastic parts: verification of deformations, hole positions
➤ Control of the metal structure of the seats
➤ Assembly checks: docking with neighboring parts
➤ Reverse engineering of old part without CAD
The Geven quality department quickly noticed the advantages of the Kreon solution in terms of its precision, speed, maneuverability and mobility. The Ace measuring arm having achieved its first objective by drastically reducing control time, it was gradually used for other applications: inspection of parts and tools and reverse engineering.
Supplied with the Kreon measuring arm, the Polyworks software is able to process and perform complex checks in a simple and intuitive way. Quality reports are produced there for an exhaustive follow-up of the analyzed parts.
For more information: www.kreon3d.com
