Photoneo’s PhoXi Gen3 Sets New Benchmark for 3D Vision in Automated Quality Control
Photoneo, part of Zebra Technologies and a leader in high-resolution 3D vision systems, has announced the launch of its PhoXi 3D Scanner Gen3.
Engineered for the most accuracy-critical applications across various industries, the 3D scanner introduces a powerful Blue Laser technology along with its integrated color camera, delivering unparalleled precision and reliability in a durable, light-weight carbon body.
The PhoXi 3D Scanner Gen3 represents the new generation of robust 3D scanner with advanced capabilities that allow for the detection of hairline cracks, micro-edges, and subtle assembly flaws with 60% more 3D data points, without compromising its robust scanning range. Gen3 also provides ultra-clear scans, empowering AI-powered inspection, tighter quality control and high-accuracy VGR applications.
“The PhoXi 3D Scanner Gen3 defines new standards in 3D scanning accuracy,” said Svorad Stolc, CTO of Photoneo. “We’ve listened to our customers’ needs for higher accuracy, better material handling, and unmatched reliability, and this new scanner delivers on all fronts. Its blue laser technology, integrated color capture, and autonomous maintenance features will redefine how businesses approach quality control, logistics, and automation.”
Key Innovations and Benefits:
Top-Notch Color Data: Featuring an integrated RGB camera, the Gen3 captures both 3D data and color texture simultaneously, simplifying tasks like verifying labels, finishes, or material blends for enhanced quality assurance, sorting, and texture analysis.
Unrivaled Surface Versatility: The scanner effortlessly handles challenging surfaces, including black plastics, reflective metals, rubber, and matte finishes, achieving up to 5 times better 3D data completeness on complex materials, eliminating wasted time and rescans.
Exceptional Range and Detail: Gen3 is fully calibrated for distances up to 4 meters, with robust accuracy up to 6 meters for larger logistics tasks, ensuring trustworthy 3D vision for both close-up inspections and long-range object detection.
Double the Speed, No Trade-Offs: Gen3 supports advanced parallel scanning using both blue and red laser variants concurrently, with no interference between wavelengths. This dual-channel architecture dramatically increases scanning throughput and data density without compromise.
Zero Maintenance: With autonomous maintenance capabilities, the Gen3 eliminates the need for special marker patterns, physical access, or service calls. Users can auto-maintain the device with a single click, ensuring submillimeter accuracy that doesn’t drift over time and keeping production lines always running.
Dependable, High-Precision Results:
- 1 MP 3D resolution
- 60% more 3D points
- 8 MP RGB data
- Operates in any lighting conditions – even direct sunlight
- Up to 2.5× better scan completeness on difficult materials
- 20 dB higher dynamic range
- Any distance from 0.3 m to 6 m
- Autonomous Maintenance – no marker patterns, no tuning, no hassle
For more information: www.photoneo.com
