Mitutoyo Announces Upgraded QuantuMike Digimatic Micrometer
The upgraded QuantuMike is an essential tool for professionals seeking reliability, accuracy, and usability in their handheld measurement devices. Engineered to keep up with manufacturing and quality control advances, this digital micrometer brings innovative technology to
measurement tasks.
Contrary to a standard micrometer with a 0,5 mm screw lead, the thimble of the QuantuMike moves the spindle 2 mm in one single rotation, reducing the approach time by approximately 60%. This makes it the perfect solution when various dimensions need to be measured quickly. Moreover, with an accuracy referring to EN ISO 3611 of JMPE ±1 µm (0-25, 25-50 mm model), the QuantuMike is ideally suited for applications requiring exceptionally precise measurements and stringent accuracy. It can also be used with confidence in the presence of water, oil, or dust, thanks to its IP65 protection level.
Built to perform reliably, this innovative digital micrometer performs well even under demanding conditions in various workplaces. Facilitating safe operation for even inexperienced users, the QuantuMike’s advanced warning system detects excessive speed collisions with workpieces. Thanks to its tolerance judgment, it significantly reduces the risk of human error and thanks to the calibration schedule warning function, the operator will never miss the prescribed calibration interval again.
The option of a calculation function allows the display of tolerance-related correction values to be entered directly into the machine. The QuantuMike boasts exceptional usability, with a large display with excellent visibility, large buttons, and key customization, which seamlessly exceed the usability of its predecessor. Moreover, bidirectional serial communication facilitates the straightforward configuration and control of digimatic devices. Users can individually manage this QuantuMike straight from a PC, with the ability to adjust settings as needed.
For more information: www.mitutoyo.eu
