Micro-Epsilon Introduces High-Precision Laser Distance Sensor
Micro-Epsilon has unveiled the optoNCDT ILR3800-100, a cutting-edge laser distance sensor that delivers exceptional signal stability and precision across a variety of surfaces. Designed for industrial applications requiring accurate long-distance measurements, the sensor can measure distances up to 150 meters with a reflector and up to 100 meters without one. With a high measuring rate of 20 Hz and a resolution of 0.1 mm, the ILR3800-100 ensures superior performance in demanding environments.
High Performance for Industrial Applications
The optoNCDT ILR3800-100 is particularly advantageous for OEM users, offering high repeatability of less than 300 µm and excellent linearity within ±1 mm. Its robust aluminum housing, lightweight design, and IP67 protection rating make it ideal for integration into industrial processes, ensuring durability and reliability in harsh conditions.
Equipped with an innovative AUTO measuring mode, the ILR3800-100 is capable of accurately measuring dark, partially reflective, and distant targets. This feature enhances its versatility, making it suitable for a wide range of applications, including automation, conveyor technology, and the metal and steel industries. Users can easily configure the sensor settings through the intuitive sensorTOOL software, further simplifying integration and operation.
Specialized Variant for Extreme Conditions
For operations in extreme outdoor conditions, Micro-Epsilon offers the ILR3800-100-H variant. This model features an integrated heating system, enabling reliable measurements in temperatures ranging from -40°C to +55°C. The sensor’s rugged design ensures optimal performance even in the most challenging environmental conditions.
Installation of the ILR3800-100 is both quick and secure, thanks to the integrated mounting plate with four set screws. An optional aluminum mounting plate is also available for enhanced stability and precise alignment. These design features facilitate effortless deployment in industrial settings, reducing setup time and ensuring accurate measurement results from the outset.
Micro-Epsilon’s optoNCDT ILR3800-100 represents the next generation of laser distance sensors, setting new standards in precision, reliability, and ease of use. With its ability to measure long distances with exceptional accuracy, the sensor is an indispensable tool for industries that demand high-performance measurement solutions. Whether in logistics, automation, or steel processing, the ILR3800-100 provides the precision and durability required for modern industrial applications.
