Is White Light 3D Profiler Actually a Digital Holography System?
Chief Scientist Peter de Groot and Technology Fellow Leslie Deck at Zygo Corporation have co-authored a historical review article that highlights the contribution of holography to the advancement of interferometric measurements of surface topography.
ZYGO produces a range of interferometry-based optical metrology tools that support and enable the most demanding metrology applications across a wide range of industry sectors. The Company is constantly researching and refining interferometry-driven optical metrology tools and recognizes that digital holography is gaining significant momentum in the measurement of surface topography due to increases in the speed and data capacity of today’s computers.
 De Groot says, “The goal of this article was to discover concepts and inventions in holography that have contributed to the advancement of classical interferometric methods that are not normally thought of as holography. By doing this, the idea was to highlight some of the significant — and perhaps surprising  — developments in interferometer design, data processing, and physical optics theory inspired by holography. Comparing holography with interferometry requires some impressions of how these two technologies differ, and how they are the same.”
Essentially, holography is a two-step process, first recording the amplitude and phase of a propagating wavefront as an intensity image — the hologram — using interference with a reference wavefront, and second reconstructing the propagating wavefront from the intensity image using optics or a digital simulation. The reconstruction of the propagating wavefront enables the image focus and perspective to be changed, leading to the famous 3D imaging capabilities of the technique. One of the miracles of holography is that despite the sometimes-indecipherable holographic patterns, it is not only possible to create these 3D images, but also to quantitatively analyse vibrations, deformations and shape using multiple and time-averaged exposures.
Interferometry is also a two-step process, but classical interferograms are created and interpreted in ways that are distinguishable from holography. Interferometry does not normally include the uniquely ‘holographic’ step of recreating a propagating wavefront from the recording of the original scattered light. For surface topography measurements, the interferogram is most often captured at the position of best focus of an imaging system, and the structure of the interference pattern is mapped directly to surface coordinates.
Notwithstanding these distinctive characteristics, interferometry and holography share the common principle of holistically recording the magnitude and phase distribution of propagating light reflected from an object as an intensity pattern, using the interference of reference and object waves.
The published paper looks in detail at specific developments in holography and interferometry ranging from data acquisition to fundamental imaging theory in three dimensions that illustrate the synergistic developments of holography and interferometry. Examples include methods for vibration-robust interferometry, enhanced signal to noise, measurements of aspheres and freeforms using computer-generated holograms (CGHs), physical modelling of interferometry using 3D transfer function, and the analysis of deformation and vibrations. Advances include a digital holographic Fizeau interferometer for optimizing instrument focus using software, and data analysis of white-light interferometry using methods inspired by innovations in holography that date from the early 1960s.”
Given the similarities of holography and interferometry, it can be tempting to conclude that these two techniques are one and the same thing. While the paper clearly illustrates that this not the case, a clear trend emerges of increasingly close developments of holographic on interferometric methods for surface topography measurements. This trend may eventually lead to a fusion of holography with techniques not normally thought of as holographic. De Groot concludes that “This evolution in applied optical metrology will surely lead to significant new solutions going forward.”
The paper was written as part of a collaboration with Prof. Rong Su at the Shanghai Institute of Optics and Fine Mechanics and Prof. Wolfgang Osten at the University of Stuttgart and is available for download by open access from the journal ‘Light: Advanced Manufacturing’.
