Empowering Robots to See Farther and Navigate Smarter
At the Automate 2025 expo in Detroit Orbec has unveiled its Gemini 435Le, the latest addition to its industrial-grade stereo vision lineup, delivering substantial enhancements for industrial applications and offering industry-leading depth sensing performance.
As robotics applications expand into more complex and precise scenarios, the market demands higher accuracy and greater reliability in 3D perception. Drawing on over a decade of industrial experience, Orbbec introduces the Gemini 435Leânot to disrupt, but to complement its product portfolio by addressing the technology gap between high-demand and fragmented use cases, with a focus on precision adaptability.
Key Features of Gemini 435Le:
Long-range, High-precision Sensing: Optimized for robotic vision, the Gemini 435Le provides low-noise, high-density depth data even while in motion. This is crucial for large robots to achieve stable positioning, navigation, precise obstacle avoidance, and object recognition in complex environments, significantly enhancing robotic path planning efficiency.
Exceptional Reproduction of Object Edges and Contours:Â Even with intricate object contours, Gemini 435Le accurately reproduces target edges and effectively identifies pallets made from various materials, meeting high-precision recognition and measurement needs. At the Orbbec booth, visitors can witness direct performance comparisons where Gemini 435Le outputs complete depth images in complex, mixed-material scenesâshowcasing superior environmental adaptability and sharp, distortion-free geometric edges for smoother, clearer object contours.
Scene-configurable Depth Modes for Flexible Adaptation:Â Gemini 435Le comes with multiple preset depth modes and supports easy switching through software configuration.
In AMR Perception Mode, the camera prioritizes depth data completeness and stability, optimizing for mobile navigation and obstacle avoidance.
In Dimensioning Mode, it focuses on delivering highly accurate edge imaging of pallets, even in low-light ‘dark factory’ environments or under complex lighting conditions.
With versatile functionality consolidated into a single device, Gemini 435Le significantly reduces customersâ hardware costs and simplifies system integration. Users can easily switch modes through a straightforward SDK interface, effectively addressing imaging challenges in emerging, fragmented application scenarios across industries.
For industrial-grade reliability, the Gemini 435Le features IP67 protection against dust and water, passes rigorous electromagnetic compatibility (EMC) testing, operates stably across a wide temperature range (-10°C to 50°C), and meets ESD Class A standards for vibration and shock resistanceâensuring long-term dependable operation in harsh industrial environments.
“The Gemini 435Le represents another important milestone in our pursuit of industrial-grade 3D vision excellence,â said Brad Suessmith, Robotics Sales Manager at Orbbec. âItâs not about disrupting for the sake of disruption, but about delivering highly adaptable, high-performance solutions that empower customers to succeed across even the most diverse and fragmented industrial automation scenarios.â
For more information: www.orbbec.com
