e-con Systems Launches Darsi Pro High-Performance Edge AI Vision Platform
e-con Systems, a provider of embedded vision solutions, launches its first Edge AI Vision Box—Darsi Pro built on the NVIDIA Jetson platform at CES 2026 Expo taking place from January 6–9, 2026 at the Las Vegas Convention Center.
Darsi Pro delivers up to 100 TOPS of AI performance, and integrates powerful cloud-based device management, multi-sensor connectivity and rugged industrial reliability – offering a production-ready platform for next-generation autonomous systems. Darsi Pro GMSL variant supports connectivity up to 8 synchronized GMSL cameras and is compatible with NVIDIA JetPack 6 and higher versions.
e-con Systems sets a new standard by becoming single trusted vendor for sourcing and integrating compute modules, carrier boards, cameras, and software frameworks. e-con brings a unified platform built to work seamlessly out of the box. Backed by deep expertise in embedded imaging – including GMSL2/FPD-Link/Ethernet cameras along with advanced ISP tuning e-con launches Darsi Pro, ensuring reliable and consistent performance for all intelligent vision-driven use cases.
Key Capabilities of Darsi
Darsi Pro brings a powerful set of features targeted for advanced autonomous workloads of the next generation Physical AI applications, featuring:
Extensive Camera Compatibility: Supports seamless integration with e-con Systems’ wide range of embedded cameras, offering flexibility to select the right imaging module for diverse vision applications.
Multi-Sensor Fusion: Supports synchronized inputs from cameras, LiDAR, radar, IMUs, and other sensors using Precision Time Protocol (PTP) for real-time perception and decision-making.
Flexible Connectivity: Dual GbE with PoE, USB 3.2, HDMI, CAN, GPIO, IMU and wireless modules for deployment across diverse environments and mobility platforms.
Cloud Management: e-con’s CloVis Central, the powerful cloud-based device management platform enables secure OTA updates, remote configuration, device and health monitoring.
Industrial-grade reliability: Built with a rugged enclosure for wide operating temperature range and field-ready durability for demanding indoor and outdoor environments. e-con Systems is also developing additional Darsi variants, including a PoE based model and support for NVIDIA Jetson Thor.
“e-con Systems is entering a new phase—moving from a camera provider to a complete vision and compute platform partner. Darsi Pro, powered by NVIDIA Jetson, simplifies the entire edge AI deployment cycle by bringing edge AI compute, multi-sensor connectivity, and proven camera expertise together in one rugged solution. This gives developers a faster, more reliable path to production for Autonomous Mobile Robots (AMR), Delivery Robots, Warehouse Systems, and Intelligent Transportation Systems and all from a single source” said Ashok Babu, President at e-con Systems.
For more information: www.e-consystems.com
