Compact 8k Super Resolution GigE Vision Line Scan Camera
Teledyne DALSA, a Teledyne Technologies company, has announced that its Linea Lite 8k Super Resolution camera is now in production. This compact and cost-effective GigE line scan camera delivers 8k resolution images, a performance that normally requires a camera body twice the size.
Built for a wide range of machine vision applications, Linea Lite cameras have a 45% smaller footprint than the original Linea and are based on Teledyne’s proprietary multiline CMOS image sensor design. This new 8k Super Resolution Monochrome camera uses two 4k/7 μm pixel rows with pixel offset. Data from two 4k/7 μm images is captured simultaneously and then reconstructed to achieve a super resolution image of 8k/3.5 μm in real time, significantly enhancing signal-to-noise ratio and the detectability of subpixel defects. Teledyne DALSA’s patented technology allows for the use of 4k/7 μm lenses and lighting without sacrificing on responsivity and MTF (due to the smaller pixel size). The camera is compatible with standard M-42 lenses, significantly saving on the total system cost.
Using Teledyne’s Sapera™ LT software, the Linea Lite 8k Super Resolution camera delivers data throughput at twice the bandwidth of a standard GigE interface, providing 25 kHz at full 8k resolution, i.e. 205 MB/sec. Speed can be further increased using Teledyne’s award winning TurboDrive technology, which pushes past the gigabit Ethernet speed ceiling. The new Super Resolution technology also significantly boosts speed for inspection systems, and Power over Ethernet (PoE) enables a single cable to drive both the data connection and power source.
For more information: www.teledynedalsa.com
