Combined Touch Probe and Confocal Sensor Machines Drive Quality Assurance Forward
At the annual Control Exhibition VICIVISION will present new 2025 innovations at the event dedicated to quality assurance and metrology technology. VICIVISION will showcase the possibility of combining confocal and touch probe in one single Techno Series machine.
The powerful combo allows for dual non-contact and tactile measurement capabilities to meet a wide range of complex measurement demands. The Confocal System can perform fast, accurate, non-contact measurements of complex surfaces and hard-to-reach areas for splined shafts, while the Touch Probe supports shaped-defect measurements needs such as axial run-out, flatness, perpendicularity, and keyway dimensions.
Efficiency, precision and seamless integration by providing multiple measurement modes within a single device, enhancing efficiency and reliability which optimizes production workflows. Through the strong combination of non-contact and contact measurement technologies, the Techno Series redefines the possibilities of precision measurement. Its multifunctional design not only enhances production efficiency but also significantly optimizes quality control processes, making it an indispensable tool in modern industrial environments striving for excellence.
Below is a preview of the models and highlights you can expect to see at our booth:
Techno Series 609 With Confocal Sensor: The Techno Series now supports confocal functionality even on smaller-range equipment, enabling compact machines to achieve the same measurement capabilities as larger equipment. This upgrade enables precise and reliable measurements that were previously challenging to achieve in compact setups.
Techno Series 914 with Confocal Sensor and Touch Probe:Â Techno 914 integrates advanced confocal system with contact probe technology in a single machine, setting a new standard for precision measurement. This powerful combination allows for dual non-contact and tactile measurement capabilities to meet a wide range of complex measurement demands.
Prima 909: The Prima Series has been further upgraded with a significant increase in measurement range (900 x 90 mm), providing users with a broader range of applications and greater possibilities, in order to meet the requirements for measuring higher workpieces, adapting to more industrial applications. This update makes the Prima Series not only more powerful in performance but also brings greater flexibility and adaptability, making it the ideal choice for measuring large components.
For more information: www.vicivision.com
