MICRONITE Aims to Redefine the Role of CMM Metrology for Proactive Process Control
For decades, coordinate measuring machines (CMMs) have served as the final arbiters of dimensional accuracy, verifying whether manufactured parts meet specification before they leave the production floor. But according to a new technical paper from Expert Manufacturing Systems, traditional inspection workflows are only scratching the surface of the value contained within CMM measurement data.
In the paper ‘CMM Accuracy Validation and Error Control โ€“ A New Measurement Intelligence Framework’, Dr. Stephen Birman introduces MICRONITE, a framework that seeks to transform CMMs from passive inspection devices into active process-control tools capable of identifying hidden measurement bias, validating multi-CMM environments, and providing manufacturing intelligence that extends far beyond conventional metrology.
Moving Beyond Traditional CMM Inspection
The paper argues that while manufacturers increasingly rely on dimensional data for quality assurance and process capability studies, the measurement systems themselves are rarely subjected to the level of scrutiny applied to the machining processes they monitor.
Rather than simply confirming that a part is within tolerance, MICRONITE proposes using CMM data to create a continuous digital feedback loop linking:
  • Dimensional measurements
  • Cutting tools
  • Machining operations
  • Corrective actions
  • Process outcomes
The result, according to the author, is a manufacturing environment where measurement data becomes a real-time driver of process optimization rather than simply a record of inspection results.
Challenging Conventional Measurement System Analysis
A central theme throughout the paper is the limitation of traditional Measurement System Analysis (MSA) and Gauge R&R studies when applied to modern CNC coordinate measuring machines.
Dr. Birman argues that conventional GR&R focuses primarily on repeatability and reproducibility while overlooking systematic sources of error unique to automated CMMs, including:
  • Probe orientation
  • Probe qualification
  • Machine-to-machine variation
  • Configuration-dependent bias
  • Measurement location
  • Hidden reference shifts
The paper suggests that a CMM may demonstrate excellent repeatability while consistently producing measurements that differ from another equally calibrated machine or from a trusted reference artifact. In these cases, repeatability alone is insufficient to establish measurement correctness.
Hidden Bias in Multi-CMM Environments
Perhaps the most significant contribution described in the document is the concept of configuration-dependent measurement states.
Using controlled sphere studies and production-part investigations involving multiple CMMs and probe configurations, the author reports repeatable but systematic measurement shifts between machines and probe orientations.
In one study involving six production CMMs evaluated across five probe locations, measurement capability varied significantly depending on probe configuration. According to the paper, some configurations produced more than five times the variation observed in others despite all machines being considered calibrated.
The implication is important for manufacturers operating multiple inspection systems.
If identical parts measured on different CMMs produce consistently different results, capability studies, PPAP submissions and production acceptance decisions may be influenced by measurement-system behaviour rather than actual manufacturing variation.
Separating Measurement Error from Process Variation
MICRONITE attempts to address this challenge by decomposing measurement error into distinct engineering components, including:
  • Configuration-dependent calibration error
  • Inter-CMM systematic bias
  • Reference-related bias
  • Production-phase measurement error
Rather than treating total variation as a statistical quantity, the framework seeks to identify the physical source responsible for each component of measurement uncertainty.
The paper argues that this decomposition enables engineers to distinguish genuine machining problems from measurement-system effects before unnecessary tool offsets, machine adjustments or corrective actions are introduced.
Introducing Minimum Measurable Tolerance
Another concept introduced is Minimum Measurable Tolerance (MMT).
Instead of assuming every calibrated CMM is suitable for every tolerance band, MICRONITE proposes calculating the smallest tolerance interval that can be measured reliably after accounting for configuration shifts, inter-CMM bias and repeatability.
Using the methodology presented, total measurement error is combined to establish an MMT below which reliable production decisions cannot be made.
The objective is to provide manufacturers with a practical guideline for determining whether a particular measurement system is capable of supporting increasingly demanding tolerances.
Connecting Metrology with Process Control
Beyond measurement validation, MICRONITE positions itself as a manufacturing execution framework that links dimensional inspection directly to machining operations.
The software integrates imported CMM data with operational control plans, predictive models, tooling information and inspection history to provide what the author describes as a continuous process-control chain.
Rather than viewing inspection as a post-process activity, measurement becomes an operational input capable of supporting predictive quality control, adaptive inspection strategies and corrective-action verification.
A Broader Vision for Manufacturing Intelligence
The document ultimately presents MICRONITE as more than a measurement analysis tool.
Its broader ambition is to establish what Dr. Birman describes as Measurement Intelligence – a methodology that validates measurement reliability while transforming inspection data into actionable manufacturing knowledge.
According to the paper, this represents a shift away from statistical evaluation alone toward engineering-based validation of measurement correctness, interoperability and production readiness.
Metrology News Perspective
The challenges associated with measurement-system trust in multi-CMM environments are becoming increasingly relevant as manufacturers pursue closed-loop manufacturing, digital twins and autonomous process control. As dimensional data assumes a greater role in automated decision-making, understanding not only the precision of a measurement system but also its underlying biases becomes increasingly important.
MICRONITE presents an ambitious framework that questions some long-standing assumptions surrounding CMM validation, particularly the reliance on repeatability as the primary indicator of measurement quality. While many of the concepts outlined in the paper will undoubtedly stimulate discussion among metrology professionals, broader industry validation and independent evaluation will ultimately determine how widely these methodologies are adopted.
Nevertheless, the work highlights an important evolution in manufacturing metrology: moving beyond simply measuring parts toward understanding the quality, reliability and operational value of the measurement data itself.
MICRONITE will be exhibiting at the upcoming IMTS 2026 Expo in Chicago in Booth #135723.
For more information: www.htrmicronite.com
