Tarus Launch Granite Bridge CMM Range
TARUS has announced a new range of air bearing granite bridge Coordinate Measuring Machines (CMM’s) equipped with Renishaw controllers and probing systems. The Tarus full featured bridge CMM is available in 3 size ranges, Small Bridge (SB), Medium Bridge (MB) and Large Bridge (LB). All 3 of the bridge CMM ranges are fully Renishaw equipped including the controllers, measuring scales, probing systems and are fully compatible with all I++ DME platform software packages including Renishaw’s MODUS metrology software.
The all granite machines feature granite cross rail and measuring arm for robust stability and matched coefficient of thermal expansion with V-dove tail guide-ways. Precision ground straightness and flatness is specified as less than 2 arc seconds. Machines are equipped with 0.1 micron resolution optical scales and come with a comprehensive 2 year warranty.
Machine sizes range from 600mm x 800mm x 500mm to 1200mm x 2500mm x 1000mm.
For more information: www.tarus.com
