SCANTECH 3D Digitization Solution for Irregular Curtain Wall
With the rapid development of architectonics, irregular curtain walls are applied more widely than ever before. Simultaneously, the rise of such structure poses great challenges to the processing and assembly of aluminum alloy profiles.
The procedure of manufacturing profiles for irregular curtain walls is very complex, it involves structure designing, profile blanking, assembly, delivery and installation. During the process, extremely accurate data are required to produce eligible profiles.
SCANTECH KSCAN composite 3D scanner can obtain the 3D data of profiles, capture surface contour and reflect the deformation in a short time with non-contact scanning, which can improve the efficiency and quality of processing, cut the cost and reduce the reworking. That’s why KSCAN is the perfect choice for profile bending detection, profile blank machine guidance as well as unit plate assembly quality control.
Performance Benefits of KSCAN
  • Ultra-Wide Scanning Area
Scanning area reaches 1440 mm × 860 mm; finish scanning a 2m*6m unit plate within 5 minutes.
  • Few Markers Needed
Save 70% time of attaching markers
  • High Accuracy
Aerospace class ultra-high precision nondestructive inspection; Reach accuracy of up to 0.02mm, volume precision of up to 0.03mm/m.
  • No Powder Spraying Needed
No harm to the surface of the subject; Suitable for all kinds of scanning scenarios
Profile Bending Detection
Normally, many companies do not have the ability to bend straight profiles so most of them choose outsourcing processes as their solutions. However, this method has attributes of high cost and low flexibility, it even has a risk of leaking confidential scheme. These companies are also unable to inspect the profile in a solid way.
For those companies who can process the profiles, mostly they applied outdated inspection methods such as ruler inspection, which results in a higher deviation and has high requirements to the experience of inspectors.
Traditional Inspection Method
SCANTECH KSCAN composite 3D scanner can proceed non-contact inspection to the deviation of profiles, help with locating the profiles and providing position reference to subsequent processing. One of our clients greatly reduce the rework rate and improve efficiency by 60% after taking our solution.
Nominal Part Profile CAD Data
3D Profile Data
Colour map compares scanned data after inspection to digital model of profile and shows tolerance deviations.
Profile Positioning
Profile Blank Machine Guidance
After bending the profile, the blank machine is applied to cut the working allowance. When the profile is fixed on the machine tool, KSCAN can scan the whole profile and provide 3D data for programming and processing.
Compared with the traditional method, the KSCAN solution conducts programming and scanning at the same time, processing irregular pieces precisely, standardizing operation procedures, reduce waste as well as enhancing competitiveness.
Unit Plate Assembly Quality Control
Unit plate assembly is the process of integrating the profiles to a curtain unit, during which the length of diagonal and height are required.
KSCAN, with built-in photogrammetry system, provides high-accuracy grid data within 5 minutes. The eligibility of the unit can be tested with the deviation chromatogram generating from aligning the scanning data and designing model. According to the deviation chromatogram, manufacturers can fix the deviation precisely and pack the unit for installation.
Nominal Part CAD Data
Deviation Chromatogram
Advantage of SCANTECH Solutions
  • Benefit Multiple Steps
KSCAN 3D scanner can take the quality control tasks from bending to assembly and improve the accuracy.
  • Saving Costs
Waste can be reduced significantly after comparing scanning data with the as-designed model.
  • Enhanced Technical Advantage
Manufacturers can master the whole process and enhance competitiveness.
  • Standardize Production Process
3D digitization helps standardize every aspect of production process and reduce the effect of human being.
For more information: www.3d-scantech.com
