Multi-Functional High Definition Handheld 3D Scanner Launched
SHINING 3D has launched EinScan Pro HD multi-functional handheld 3D scanner. Inherited multi-functional and modular design of EinScan Pro series handheld 3D scanner, EinScan Pro HD delivers unparalleled performance in capturing high resolution and accuracy by handheld scanning. Exceptional versatility and powerful optimizations come together for the ultimate high-efficiency and professional-grade 3D scanning experience. It is reliable assistant for designers and engineers who care about high quality 3D modeling.
By adopting a new structure light projection modular, the stripe pattern scanning which was traditionally used in Fixed Scan Mode is now utilized to Handheld HD Scan Mode. With 0.2mm minimum point distance setting with optimized algorithm, it brings high resolution and accuracy in handheld scanning as good as under fixed scan.
With new lighting projection hardware and software algorithm, EinScan Pro HD is capable to scan a wider range of objects of dark or black color and casting metal surface, enriching the capability for 3D scanning of materials.
EinScan Pro HD has a dramatic breakthrough in scanning capability, and USB 3.0 provides high speed data transmission even scanning objects with complex details.
Multi-Functional Scanning
Multiple scan modes and alignments extend the user scanning experience for more applications.with selection of different modules for difering requirements offering both high accuracy and efficiency.
High Accuracy for High Quality 3D Modeling
By different kinds of positioning methods, both scanner or objects can be moved during scanning. It delivers accuracy up to 0.04 mm in Fixed Scan Mode. Under handheld scanning mode by marker alignment, the volumetric accuracy is up to 0.045mm+0.3mm/m.
EinScan Pro HD offers full-color texture and fast geometry capture using Color Pack with ich color can assist data alignment.
ExScan Pro Software
Developed by SHINING 3D , ExScan Pro is professional software for 3D scanning and data processing with a collection of both scan and mesh editing tools for generating high-quality 3D models. Either novice or experienced users can easily scan for high quality 3D data. EinScan Pro HD, includes Solid Edge SHINING 3D Edition with the mainstream 3D CAD design functions, bringing a convenient and powerful 3D design tool to help achieve creative ideas.
