Mobile Precimar Micro Measuring Bench for Short Lengths
The youngest member of the Precimar family is also the smallest. The Precimar SM 60 is a perfect tool for quality-conscious production due to its simple and therefore fast operation, robust design and great flexibility. With this small length measuring bench, external measurements can be carried out quickly and precisely – and it is suitable for both left-handed and right-handed users.
Mobile and individual in use due to its small size, simple design and robust construction, the bench is ideally suited for immediate use in the workshop or other production environments. The relatively large measuring table can accommodate work-pieces up to 60 mm in diameter. The measuring sleeve can be moved by 25 mm, depending on the dial gage. Integrated coupling additionally protects the measuring equipment. The small length measuring bench is mobile and individually adaptable to new work-pieces, allowing the measuring equipment (e.g. digital dial gage or measuring probe) to be freely combined as required.
With different measuring attachments, different types of measurements can also be carried out on the work-piece. The Precimar Family from Mahr Precimar stands for dimensional metrology in highest precision for both absolute and relative measurements. Typical areas of application are products and test equipment for the aerospace and automotive industries as well as series testing of test equipment in calibration laboratories. With various universal length measuring machines, lengths, outer and inner diameters, cylindrical and tapered threads, smooth tapers, micrometers, snap gages, dial gages, fine pointers, probes and gage blocks as well as precision products down to the nanometer range can be reliably measured and tested with maximum precison.
For more information: www.mahr.com
