Kreon Launch Zephyr III 3D CMM Scanner
KREON has launched a new generation of CMM scanners based on more than 25 years of experience in industrial metrology. Regardless of industrial sector or the measurement application, the new Zephyr III scans all kinds of parts in record time without impacting the precision of the mesh or obtained point cloud.
The Zephyr III is a top-of-the-range 3D scanner able to scan extremely complex parts at a high acquisition speed of 600,000 points/sec. Its broad laser line of 150 mm, unique on CMMs, brings a significant increase in productivity, especially with large parts. Its blue laser consistently delivers optimum measuring quality, even on black or glossy parts that are considered difficult.
Combined with CMMs, the Zephyr III is a real plus for inspection automation. Compact and compatible with multi-orientation Renishaw’s PH10 indexing probe heads, its freedom of movement allows it to scan parts with complex geometries. Due to the ability to attach a probe integral and directly underneath the scanner, the Zephyr III can scan and probe parts simultaneously in the same measuring range.
The Zephyr III has a quoted accuracy of 14 μm according to ISO 10360-8:2013, – Maximum size error on all measured points (translation mode).
With unequalled flexibility of use, the Zephyr III can also be interfaced with optical trackers, machine tools, robots and KREON measuring arms.
For more information: www.kreon3d.com
