Inline CT Equipped With Automatic Defect Recognition
The YXLON MU60 X-ray and CT inspection system is designed for a wide range of applications, especially in the foundry sector of the automotive and aerospace industries and equipped with Truelnspect ADR (automatic defect recognition), the MU60 offers the perfect in–line inspection system for large castings.
“Clear, crisp 2D industrial X-ray images are complimented by the computed tomography (CT scan) option, which allows for failure analysis in three-dimensional volume and slices. With high detail visibility and brilliant image quality, even the smallest defects in complex system geometries can be detected. Welds of bleed air ducts or hydraulic conduits are easily inspected, as well as turbine blades and structural aircraft parts.
The system is specifically designed to meet rigorous safety and quality guidelines of the aerospace sector. In order to ensure acceptable inspection quality of your safety-critical components, the MU60 AE complies with requirements of current industry standards such as MAI, Nadcap, ASTM, and DICONDE.
With the high precision CT scans even the smallest anomalies can be reliably detected making the system particularly useful in safety-critical parts like automotive brake systems, which require a higher level of visible detail to meet manufacturer’s safety and quality specifications.
The YXLON MU60 AE uses the PXV5000 system control, which allows the system to run without operator interaction. Gain and offset calibrations can be easily integrated into the inspection programs for optimal workflow and reliable results.
Image evaluation is greatly enhanced with the IMAGE 3500 imaging software which provides a wide range of processing tools including filters, gray value scaling, annotations, and HDR live image filter, which make image processing and evaluation very convenient.
For more information: www.yxlon.com
