In-Cycle Measurement Reduces CMM Bottleneck
Senior Aerospace Weston is a leading supplier of a wide range of complex precision machined components and sub-assemblies, predominantly for the commercial aviation market. At the company’s machine shop in Earby, UK, 95% of output is for use in Airbus aircraft models. Most of the components are aerostructure (wing and mainframe) components including engine pylon brackets and landing gear fittings.
Measurement Challenge
Some of the more complex aerostructure parts were taking up to 10 minutes to inspect using Senior Aerospace Weston’s existing coordinate measuring machines (CMMs). This would often cause bottlenecks and capacity limitations around the CMMs. To address the problem, the company introduced various manual inspection methods using traditional measuring equipment and hard gauging, but to limited effect.
With build-rates increasing, Senior Aerospace Weston recognized its responsibility to become even more efficient with in-cycle measurement without compromising quality.
Measurement Solution
“We spoke with Renishaw and they proposed the Equator gauge, which is another level up from a traditional 3-axis CMM in terms of speed,” explains CMM Programmer Andy Wright. The thermally-insensitive Equator system is a flexible gauge that is designed to provide speed, repeatability and ease-of-use. which was installed during January 2018.
“We have 70 part numbers that could fit on the machine, so there is high potential,” states Mr Wright, who is also impressed with the system’s ease of use. “No special skills are required; the operator simply loads the part into the fixture, lets the cycle run and receives an easy-to-read report.”
Another factor behind the success of the project has been the sales and applications support from Renishaw: “The support we receive is first class,” says Mr Wright. “Renishaw is very quick to answer any queries, and it almost feels like we’ve been assigned our own special support team.”
A key part of the support team for Senior Aerospace Weston is Renishaw Applications Engineer, Ed Clarke, who comments: “For any customer with a turnkey project we will provide ongoing support for all stages of their project. If there are any queries, the customer can come directly to us for the support they require.”
Measuring Results
Among the parts inspected at Senior Aerospace Weston using the Equator gauge is a titanium wing flap track component for Airbus aircraft.
“Over the years we have gone through several process iterations and various equipment solutions trying to measure this part quicker with the required accuracy, but inspection would regularly fail due to component complexity and tight datum tolerances,” concedes Mr Wright. “However, using the Equator gauge we have been able to achieve a process that delivers accurate gauging and repeatability. The Equator gauge measures around 25 different features on this particular part, taking just 90 seconds in total.”
“The in-cycle measurement time has been significantly reduced, with our operators now just reviewing an electronic report,” says Mr Wright. “Inspection cycle time has been cut by 75%. Previously a manual measurement would be taken and recorded on paper; now, we have fully electronic reports with every dimension recorded. We can also use trend data to help identify potential areas for improvement in our manufacturing process.”
