High Accuracy 3D Optical Profiler System Launched
Santec Corporation, a leading manufacturer of advanced optical components, tunable lasers, optical test equipment and OCT systems, has announced the launch of its 3D Optical Profiler, OPS-1000. Supporting R&D and production environments the OPS-1000 delivers fast, accurate and wide 3D object scans with high sensitivity capturing surfaces.
The Santec Optical Profiler System uses the combination of a high-speed tunable laser and an interferometric detection technique to bring record sensitivity to a single beam, non-contact optical profiling. The OPS-1000 is designed to deliver high speed, high accuracy, non-contact measurements regardless of shape material, color or surface shape of the target object. OPS-1000 utilizes a coherent measurement principle; so is not affected by ambient light in a production environment delivering reliable data.
The OPS-1000 operates at a sensitivity of 100dB. In addition, the system dynamic range of >70dB captures 400,000 points per second Intuitive control software allows the user to quickly configure scan profiles, automate testing, and export the point cloud data for analysis. The single beam geometry minimizes structural interference within shapes and structures. The OPS-1000 can be configured with a measurement range of up to 1m.
For more information: www.santec.com
