Focus-Variation Technique in Comparison
Accurate measurement solutions with high resolution are a necessity whenever surface qualities and micro geometric features need to be examined. In comparison to alternative optical technologies, Focus-Variation closes the gap between typical 3D coordinate measuring technology and classical surface metrology devices.
Profile Projectors
Profile Projectors and other image processing systems are the predecessors of present optical measurement systems and are still relevant for understanding optical measurement technology. Profile projectors enlarge the components‘ surface characteristics and project the image onto a screen. Through pattern matching the image is compared to an appropriate reference. Advantages are measurements that can be executed within seconds, although the automatic measurement of geometric features is limited to two-dimensional applications only. One main disadvantage is its sensitivity to object alignment. Depending on its orientation, differing measurement results can be obtained.
Structured Light
Structured Light is based on a projector that illuminates the measurement object with several bright and dark stripes and captures it with at least one camera. The topography of the sample distorts the stripe pattern of the projector. The distorted pattern is recorded with a camera and, finally, the topography is calculated via image processing. One advantage of structured light is the high measurement speed when measuring large surfaces. Therefore, the technology is primarily used for the measurement of very large parts such as vehicle bodies. The technology is of limited suitability for high-resolution sub-µm depth measurements as, for example, with roughness measurements. In addition, the low depth of field and high sensitivity to varying surface characteristics substantially limit the application range.
Confocal Measurement
Confocal Measurement is characterized by its high lateral resolution. Right at the focal point inside the detector an additional aperture is used to block light from above and below the focal plane. Thereby, only light within the focal plane passes through the detector. By detecting the strongest signal depth is measured. Confocal systems are particularly suitable for measurements of very smooth surfaces that can be found on silicon structures or semiconductor geometries. The advantage of high resolution in z is accompanied with increased sensitivity towards vibrations.
White Light Interferometer
White Light Interferometer use interference effects in order to determine topographical features. One advantage is the high vertical resolution. While rough surfaces are difficult to measure the method is ideally suited for the evaluation of lenses and glass structures.
Focus-Variation
Focus Variation gathers not only depth information but also registered true color information of the surface. Roughnesses of micro and nano-structures are measured both profile and area based. Complex geometries are measured via the Real 3D technology from different perspectives which are then merged into a full 3D dataset. By measuring form, dimension, position and roughness in one system, Focus-Variation closes the gap between typical 3D coordinate measuring technology and classical surface metrology. In contrast to profile projectors not an outline is measured, but the components‘ 3D surface. While confocal systems and interferometers measure intensity peaks or intensity modulation only in a very narrow band around the focal point of the system, Focus-Variation measures sharpness over a considerably larger region. Therefore, the technology is much more tolerant against vibrations.
