Fixture Tables Support Portable Arm Applications
Renishaw Fixturing Solutions metrology tables are now available as a stock option for even faster delivery.  The metrology table top is created using a M6, M8 or ¼-20 threaded cast aluminum plate and supported with rigid aluminum extrusion legs that can withstand large and heavy parts. The fixture plate can also be ordered with a black anodize finish to minimize reflections for optical inspection. With the addition of a small adapter plate, the table is compatible with any portable CMM, white light or laser scanning system. Renishaw metrology fixturing tables are ideal for use in any industry.
Metrology tables are available in any size to suit customer requirements.  Standard tables come fully assembled so users can simply uncrate and get to work immediately.  Tables are completely customizable by adding additional features such as drawers, shelves and monitor or laptop brackets.
Each table is fitted with leveling feet for easy table height adjustment. Casters can be specified with integrated self-leveling feet for easy maneuverability around your metrology inspection area. Fixture plates are precision ground and hard coat anodized to resist scratching and increase durability. All plates come with alpha-numeric labeling as standard, to assist when documenting each fixture setup.
