Exact Metrology To Represent GOM CT
Exact Metrology has announced that it has become a distributor of the GOM CT scanner in the U.S. GOM is an established global company and leader in structured light scanning technologies and develops software, machines and systems for industrial and automated 3D coordinate measuring technology, 3D computed tomography, as well as 3D testing.
GOM’s computed tomography (CT) scanner provides 3D data of internal and external component geometries in exceptionally high resolution. The GOM CT produces the finest details visible throughout the component, simplifying initial sampling, tool correction and inspection tasks during production. It captures complex components including the “inner workings” in a single scanning process, so that the user receives a complete image of the test specimen for form and position analysis or nominal/actual comparisons. The system shows its greatest strengths when digitizing smaller plastic and light metal parts.
High-Contrast X-ray Detector and 5-Axis Kinematics
To achieve a very high level of detail during component digitization, the components of the GOM CT are perfectly matched to each other: A high-contrast 3k X-ray detector generates a very fine pixel grid (3008 x 2512 pixels) and thus lays the foundation for high-precision detection of the measured components. 5-axis kinematics, with integrated centering table, makes it easier for the user to position the component optimally in the measuring volume, so that the measurement is always performed with the best possible resolution. In additional, within the measuring volume, (diameter: 240 mm, height: 400 mm) several objects can be measured simultaneously in one scan, further reducing processing times. Due to the proven GOM technology the GOM CT ensures high precision and repeatable measurement results.
Data Acquisition and Evaluation Software
As with all GOM metrology systems, the control of the device, data acquisition and evaluation are combined in a single software package. means that no further software is required greatly simplify the chain from recording the raw data to creating the measurement report.
Exact Metrology will house a GOM CT scanner at their Brookfield, Wisconsin location which will be used for customer demonstrations and educational purposes, as well as contract scanning.
For more information: www.exactmetrology.com
https://www.gom.com/uploads/tx_livideo/gom-ct_no_inspection_12Mbit.mp4
