Electric Vehicles Drive Transition to Flexible Gauging
Renishaw has delivered several thousand Equator gauging systems to global customers over the last few years, with extensive presence in all the European, American and Asian automotive markets. Significant investment in research and an increase in Electric Vehicle (EV) production has generated additional inspection requirements where Equator gauging systems have come into their own.
EV motors, generators, transmission gears and casings – all examples of parts where production lines and cells now rely on the process control capabilities delivered by the Equator gauging system, at the point of manufacture. Motor stators are a prime example – the high-speed scanning capability of Renishaw’s SP25 probe used by Equator systems, coupled with Renishaw’s powerful MODUS programming software, is ideal for assessing the demanding size, position and geometric tolerances on the ID and concentricity of an assembled EV stator – critical to guarantee motor efficiency.
The same Equator system can also use a Renishaw TP20 touch probe to collect single point data at a rate of up to three points a second – perfectly suited to gauging the relative positions of multiple edge points on a stator lamination plate.
Direct Process Control Where It Matters
IPC (Intelligent Process Control) software, developed with help from many end users across multiple industries, is an optional feature available on all Equator systems. This software allows constant monitoring and automatic adjustment of machining operations, keeping part dimensions close to nominal and within process control limits. This correction of process drift improves part quality and manufacturing capability, thereby reducing scrap and quality costs.
Automated Cells Versus Manual Gauging Stations
Equator gauges can be quickly configured to meet the same application demands of dedicated gauging systems. With the reduction in automotive design lifecycles in recent years, fast and efficient re-deployment of Equator gauges to new lines and cells is a major advantage over part specific gauges which require time consuming redesign, costly rework or being scrapped altogether. In addition, with increased demands for factory automation, Equator machines are perfectly suited for integration with robots and conveyors. The new EQ-ATS (Equator Automatic Transfer Systems), for Equator 300 and Equator 500, allows parts to be loaded at the front of the device, and transferred in and out of the measuring volume under automatic program control.
In some situations, particularly with very harsh environments, Equator systems are placed in an optional enclosure; an EQ-ATS system may also be fitted so that the parts can be loaded safely and easily outside of the machine volume.
Renishaw will showcase a number of Equator systems gauging a range of electric vehicle and hybrid engine and transmission components from real customer applications being gauged by Equator systems ‘24/7′ in factories around the world at the upcoming EMO Hanover exhibition from 15th – 21st September in hall 6.
