Compact Microscope Simplifies Daily Lab Work
ZEISS has introduced a new compact microscope. The Primostar 3 is a robust upright light microscope, which is made for daily work and designed for long-term use and extreme durability while being easy to learn and run with quick and easy setup with a plug-and-play installation.
Users can choose the best microscope configuration for specific tasks at hand from a number of pre-defined packages. The solid design of the Full-Köhler version houses an array of clever features and users can choose either a 30-watt halogen bulb or an energy-saving LED bulb with its stable color temperature and illumination intensity. Users can add-on a fluorescence tube and turn ZEISS Primostar 3 into an LED fluorescence microscope.
ZEISS Primostar 3 has a small footprint, is compact with all cables stored directly on the microscope. ZEISS Primostar 3 is made of solid materials, designed for durability so that even after years of daily and intensive use, all components will work smoothly reflected in the ZEISS extended warranty o f5 years.
Inspiring Digital Interface Options
ZEISS Primostar 3 offers the advantages of an integrated 8-megapixel microscope camera and a number of additional digital interface options. With the imaging app ZEISS Labscope, it is easy to connect microscopes to each other and makes it easy to snap and share microscope images via HD monitors or projectors.
For more information: www.zeiss.com/microscopy/
