Compact Laser Triangulation Sensor Offers High Performance
The optoNCDT 1900 is the latest model of Micro-Epsilon laser sensor; this innovative sensor is used for dynamic displacement, distance and position measurements and impresses with high speed, design and accuracy. The integrated high-performance controller enables fast and highly precise processing and output of measurement values. The optoNCDT 1900 laser triangulation sensor is used whenever maximum precision is combined with the latest technology such as advanced automation in the automotive industry, 3D printing and coordinate measuring machines.
The optoNCDT 1900 offers a unique combination of speed, size, performance and application versatility. This compact triangulation sensor achieves a high measurement accuracy and measuring rates of up to 10 kHz. The high-performance optical system generates a small light spot which enables to even detect the finest of details and structures reliably. The sensor offers measuring ranges of 10 | 25 | 50 mm and linearity from 2 µm.
For the first time, a two-step measurement value averaging is available to optimise the sensor signal providing a smooth signal at edges and steps. Especially for high speed measurements of moving parts, the high-performance averaging enables a precise signal course.
The optoNCDT 1900 is equipped with an intelligent surface control feature. New algorithms enable stable measurement results even on demanding surfaces presenting changing reflections. In addition, the sensor is extremely resistant to ambient light and can also be used in strongly illuminated environments. New algorithms compensate for ambient light up to 50,000 lux.
Mounting the sensor using fitting sleeves automatically aligns the sensor in the correct position enabling easy sensor replacement and higher precision in solving measurement tasks. the sensor compact dimensions allows integration in confined spaces.
