Z-Mike Pro Gauge Provides Absolute Accuracy, Reliability and Repeatability
The new Z-Mike Pro from NDC Technologies is the next evolution of the industry’s leading off-line part measurement system for metrology applications. The new Z-Mike Pro sports sleek, modern styling and is ready for service under Industry 4.0 with expanded connectivity, communication and control capabilities.
Z-Mike Pro provides absolute accuracy, reliability and repeatability for dimensional measurements of outer diameter, ovality, taper, TIR, run-out and effective cutting diameter. Manufacturers facing increasingly tighter tolerances and the pressure to turn out precision parts efficiently rely on Z-Mike’s +/-0.5 µm accuracy and +/-0.13 µm repeatability to help deliver superior quality products. Z-Mike Pro offers versatility across a wide range of demanding measurement applications such as rubber rollers, fluted cutting tools, plug and pin gauge calibration, shafts, pistons, crankshafts, camshafts, motor shafts, glass tubes, fuel injectors, valves, computer components and other applications.
From quality clean rooms to hostile machine shops environments, the Z-Mike Pro gauge offers the following benefits:
  • No recalibration
  • Precision over the entire measurement range
  • No requirement to center the object to be measured
  • Traceable measurements to national standards
The Z-Mike Pro gauge is available in two models to measure products up to 50 mm. Ethernet and USB connectivity simplifies integration into centralized production networks and other devices. An extensive line of ready-to-mount modular fixtures are also available to hold work-pieces, from simple manual fixtures to fully automated and intelligent fixtures.
For more information: www.betalasermike.com
Faro Introduces RevEng Seamless Scan to CAD Software Solution
