What is Smart Manufacturing?
Smart manufacturing is really all about data.  It’s about collecting and using accurate data to make good decisions quickly to allow for slick, efficient and flexible manufacturing which can adapt to sudden changes in demand or circumstances.  Heavily automated processes require a constant stream of data to make decisions and adjustments so that data has to come from accurate measurements using equipment which is flexible enough to still be useful if the process needs to change.  Using machine learning algorithms, smart manufacturing operations can constantly improve and streamline their processes.
Gathering Data
How data is captured, processed and used is really what is smart about smart manufacturing. Data is gathered at every stage of every process so accurate metrology is vital. The data is monitored and analysed to make sure every part of the process is as efficient as possible and collecting all of this data together to look at the entire value chain enables identification of areas which can be streamlined.  Having such a detailed and interconnected overview of the whole manufacturing process allows for adaptions to be made when changes take place.
Manufacturing Flexibility
With the current demand for customization and the need for manufacturers to be able to accommodate sudden changes in trends, smart manufacturing systems have to be flexible enough to change quickly.  Using measuring devices which are as flexible and adaptable as the systems themselves allows for these changes to take place and the data they collect can be analysed to make sure the changes are having the desired effect or the new processes are as efficient as possible.
Efficiency Gains
Smart manufacturing and automation in general is all about efficiency but it is impossible to create ultra-efficient processes if the equipment you are using to collect the data that the whole system is so reliant on isn’t efficient or is difficult to integrate with other data-gathering equipment. Solartron’s sensors and probes are suitable for smart manufacturing because they’re highly accurate, efficient and easy to operate. Using the Orbit Digital Measurement Network, Solartron’s sensors and others can be used together to produce meaningful and easy to access data.
Faro Report Double Digit Growth
Process Visibility
It isn’t all about machines using this data, however.  The constant monitoring and analysing at every stage of the manufacturing process gives operators great insights into what is really happening during each process and gets to the root causes of problems in real time.  By allowing workers to see exactly what is going on at each stage and reporting it live to an easily accessible device, managers can make decisions instantly based on reliable data.
For more information: www.solartronmetrology.com
