Ultraprecise XXL Measurements
The Dark Energy Spectroscopic Instrument, called DESI, has an ambitious goal: to scan more than 35 million galaxies in the night sky to track the expansion of our universe and the growth of its large-scale structure over the last 10 billion years. Using DESI—a project led by Lawrence Berkeley National Laboratory—scientists hope to create a 3D map of a third of the night sky that is more accurate and precise than any other.
A precise map requires that DESI itself be built and assembled with micrometer precision. Fermilab, a Department of Energy national laboratory, is contributing a key piece of the instrument: a large, barrel-shaped device that will hold optical lenses to collect the light from millions of distant galaxies. The smallest deviation in lens alignment could lead to the instrument being permanently out-of-focus. Every piece of the barrel must be perfectly placed, so the Fermilab team is currently taking every measure to ensure its precise assembly.
The process involves a special machine, meticulous handling and a healthy dose of patience.
Precision assembly
The lens-holding device is a roughly 8-foot-long and 4-foot-wide segmented cylinder. Once the steel barrel is complete, it will be installed at the Mayall four-meter telescope at the Kitt Peak National Observatory, southwest of Tucson, Arizona.
The lenses will collect the light reflected from the telescope’s mirror and focus it into 5,000 optical fibers, through which the light is transported to special detectors, called spectrographs. With the help of 10 such spectrographs, scientists can measure the distance of the galaxies.
In May, a team of specialists at Fermilab began assembling the barrel’s five segments carefully, checking that each nut and bolt was perfectly situated. But a nuts-and-bolts-level fit isn’t enough. To achieve the precision scientists are aiming for, the DESI barrel and its inner structure must be assembled accurately to within an incredibly tight 20 microns.
To achieve the required fit, the team has been making small, critical adjustments to the assembled barrel using a Hexagon Manufacturing Intelligence large gantry style coordinate measuring machine. Jorge Montes, one of the team members, strategically places markers on the barrel’s surface to assist their alignment efforts. After making the measurement, the scientists return the barrel to an outside area where they disassemble it, realign all the parts, relying on the previously placed markers. They then reassemble it. With great care they bring the once more fully assembled barrel and measure anew with the CMM the precision of their assembly.
API Expands Services Division with Opening of New Texas Location
Comparing their performance with their previous assembly, they learn which pieces, if any, are misaligned—even slightly—and where they improved the alignment led by Fermilab engineering physicist Michael Roman to ensure the DESI barrel’s perfect assembly.
With the help of the CMM, they repeat the whole procedure of assembly, measurement and disassembly again and again, always comparing their performance against previous tries. When they reach their alignment within 10 micrometers they are satisfied.
“From early on we knew that the barrel needed high-precision measurements for the assembly and that it would be too large for any of the CMMs at Fermilab to perform such measurements,” Roman said.
“In strong support of DESI, Fermilab bought a machine for the dedicated measurements on the barrel,” said scientist Gaston Gutierrez, who is one of the DESI project leads at Fermilab.
Steady and stable
To ensure that the CMM’s measurements are as precise as they need to be, the CMM is set up in an air-conditioned room, where scientists monitor and control the temperature 24 hours a day temperature within one degree of 20 degrees Celsius.
The Fermilab team expects to finish all CMM measurements by early 2017. Then they will disassemble the DESI barrel and send it to the University College London. In London, their colleagues will install the lenses in the support structures. Once the lenses are installed, the barrel will start its journey to its future home in Arizona.
Measuring the expansion of the universe
Scientists have discovered that our universe is growing bigger and bigger—without any end in sight. Like raisins in a rising loaf of bread, the universe’s galaxies are being pushed apart from each other.
From previous measurements, scientists have a kind of cosmic ruler, a standard length that goes back to the universe’s early beginning. Using this ruler together with the high-precision DESI map, scientists will be able to tell how far galaxies have moved apart and how much our universe has grown throughout its history.
“With the DESI experiment, we want to follow the growing steps of our universe,” Gutierrez said. “We start from today and go backwards in time to measure how much the universe has expanded since its early days.”
The fabrication, assembly and operation of DESI are small but highly important steps toward precisely understanding the universe.
