Third Dimension Speeds Up MRO At World’s largest Nuclear Fusion Facility
For the last 10 years, Third Dimension has been working with the UK Atomic Energy Authority’s (UKAEA) RACE (Remote Applications in Challenging Environments) department to facilitate the development of nuclear fusion by speeding up the MRO (maintenance, repair and overhaul) process of the world’s largest experimental reactor.
As the world’s largest nuclear fusion power experiment, the JET (Joint European Torus) nuclear fusion tokamak1 is designed to harness energy with the intention of furthering the development of fusion power generation. Fusion is based on the same principle that powers our Sun and stars and is a key stepping stone towards a carbon free world in energy production.
Operated by the UKAEA at Culham Science Centre near Oxford, England for the EUROfusion consortium of European fusion scientists, the project started in 1983 and is at the absolute cutting edge of scientific development.
Third Dimension supports quality control and MRO of JET with their advanced profile measurement systems. When Third Dimension originally started working with UKAEA, a third generation GapGun was installed onsite and used for inspection, in and out of the fusion rig, for many years. However, the GapGun, designed for handheld measurements, was upgraded last year to the recently launched Vectro system.
Vectro is not only based on the latest 5th generation GapGun Pro technology, but more importantly has been specifically designed to be installed as an integrated robotic inspection tool. Already, Vectro has proven to deliver significant improvements to the speed and productivity of maintenance procedures for UKAEA. This has been achieved with the Authority’s MASCOT robot.
Tim Monks, CEO at Third Dimension, said: “JET is an important landmark on the way to making nuclear fusion a reality as a sustainable power supply for the future. Vectro is helping to maintain JET, quickly and effectively, and I am pleased that the Third Dimension team has played its part in this fantastic technology.”
During operation, the reactor runs for 30 seconds every half hour, with scientists from around the world eagerly awaiting their data and test results.
The tokamak1 has a heating capacity of around 40 megawatts. In order to achieve power generation through nuclear fusion, plasma temperatures of over 100 million degrees Celsius are required. This makes the reactor the hottest temperature in the solar system, hotter than the sun.
Inside the reactor specially designed tiles are densely packed to cover the inner area of the tokamak core and protect it from the extreme temperatures and hostile environment generated by the process. These castellated, beryllium-coated Inconel tiles are made in the USA at a cost of over $700 per hundred grams.
Tiles are around 1 cm square and are slightly offset at an angle to encourage the hot gas – known as plasma – in the core to circulate in a controlled manner. This presents a challenge to ensure that the tiles are within a strictly controlled tolerance band.
IP65 Blue Area Scanner Acquires High Resolution Images
Any excessive amount of step or gap between tiles increases the danger that plasma could cause tiles to detach or get damaged. This would then mean expensive replacements and so inspection and the correct positioning carried out on these tiles is critical to the project.
However, inevitably tiles do get damaged from time to time, often by plasma escaping from JET’s powerful magnetic fields.  Therefore, as part of regularly scheduled maintenance procedures, the JET facility is closed for six months every two years for an overhaul, and this is when the Vectro comes into play.
Due to the hostile environment of the reactor, it is left to cool for a couple of months before the MRO begins; though even then it is still unsafe for humans to enter the tokamak safely without the use of protective suits. However, Vectro thrives and is effective under these conditions and so is operated remotely with a robotic device called MASCOT.
MASCOT is mounted onto an in-vessel transporter system to enable Vectro to check for damage to the surface of every single tile lining the reactor. Each tile is inspected to see if it needs to be replaced and if so, to ensure that the replacements are re-positioned in exactly the right place and orientation.
MASCOT is a highly dextrous haptic force-feedback master-slave telemanipulator, with each kinematically similar master or slave unit consisting of two 7-degrees-of-freedom arms. The MASCOT master station is driven by experienced remote handling operators and can be positioned around the vessel by a transporter system; a 12-meter-long articulated robot (see image).
James Kent, Remote Handling Development Engineer at RACE, said: “Every tile we replace, we check with the Vectro system. This speeds up our overhaul time, which means JET can be up and running again sooner, delivering the results which will help to make fusion a dependable source of energy in the future. GapGun and Vectro are very precise. We couldn’t position or check the tiles as accurately or efficiently without them.”
“Due to the delicate high precision components within the vessel that require precise installation tolerances, Vectro gives the ability to measure steps and flush without the need to touch the component directly. The thousands of measurements that must be taken at the end of the installation phase need to be carried out in a fast and efficient way, which the Vectro fulfils extremely well.”
“The ability to create check plans using Third’s software means we can create a structured way of measuring the components and keep a history log for future installations. Furthermore, the compact nature of Vectro means we can use the device in areas of restricted access.”
During a regularly scheduled shutdown, around 600 tiles are removed and replaced during the 6 month period including many sample divertor tiles for chemical and physical examination.
Industry Shifting From 2D to 3D Inspection
The divertor is a device within the JET tokamak that allows removal of waste material from the plasma while the reactor is operating. This allows control over the build-up of fusion products in the fuel and removes impurities in the plasma that have entered from the vessel lining.
Vectro is used to check any tile that is replaced and to quality check new tiles before they are installed into the JET wall. During the 2010-2011 shutdown, every single tile was replaced (4-5,000 tiles).
The award winning GapGun technology is the only way to check that the tiles are in the right position, within 10 microns, which ensures minimal damage when the reactor is operational. It is impossible for the human eye to detect to such accuracy.
Before GapGun and Vectro, operators had to check quality by eye, using a standard gap flush test, compare against a check-list and manually input all data into a spreadsheet. This was slow and prone to error. GapGun, and now Vectro, deliver the results immediately and electronically, so operators have a record of what has been done. Saving the project time and money, they deliver repeatable results time and time again.
Using this inspection method means not only is it possible to reduce the number of tiles that fail during experiments (allowing for a higher chance of successful tests), but that in the future it could also be possible to meet even tighter tolerances.
Looking ahead to the next phase of fusion power development, the ITER2 reactor in the south of France is currently being built and is due for completion in 2035. JET is carrying out technical preparations for ITER to ensure it is a success  – playing a powerful role in the development of fusion energy.
UKAEA’s RACE is now developing the next phase of the robot, MASCOT 63, to be launched this year. Robert Howell, Mechatronics Engineer at RACE, said: “MASCOT 6 addresses the obsolescence issues present in the older MASCOT 4.5 system but also introduces performance improvements and new features. This includes: new actuator designs for both the Master and Slave units that have been optimised for performance, a modern control system with new electrical and software components, major enhancements and improvements both to the control system software and the operator’s graphical user interface, and enhanced safety features.”
For more information: www.third.com
For more information on nuclear fusion visit  https://www.gov.uk/government/organisations/uk-atomic-energy-authority,  http://www.race.ukaea.uk/.
  1. Tokamak – an experimental machine designed to harness the energy of fusion.
  2. ITER is the world’s largest fusion experiment, and will be the largest fusion reactor when it becomes operational. Thirty-five nations are collaborating to build and operate the ITER Tokamak in the south of France.
  3. Skilton, R., Fusion Engineering and Design (2018), https://doi.org/10.1016/j.fusengdes.2018.03.026
