Spring Manufacturer Uncoils Measurement Productivity
A spring manufacturer has uncoiled its productivity potential thanks to an investment in a state-of-the-art metrology solution.
UK’s Adwin Spring Co produces prototypes in both wire and flat materials, catering for a diverse client base,including some of the world’s largest companies, in both short-batch and large-volume productions.
However, when it found that traditional part-measurement methods were no longer fully satisfying the speed or accuracy needs of its growing customer base, it turned to OGP UK to help address the challenge.
Part of the Carfulan Group, OGP UK’s range of advanced optical and multi-sensor SmartScope systems can gauge the characteristics of even the most complex parts quickly and without human error, leading to better quality, reduced scrap and increased throughput.
Will Hayes, Quality Manager at West Bromwich-based Adwin, said: “Before we purchased the OGP we used traditional measuring methods of Vernier calipers, micrometers and shadowgraphs. With a lot of those methods you can get different people getting different readings that can be quite inaccurate.”
Adwin Spring were looking for an alternative method because its customers were demanding more accurate results as well as different types of reports and feature sets to what they were traditionally using, as well as 3D measurements.
“We looked into different methods such as laser scanning and other non-contact companies” We needed a non-contact form of measurement as a traditional CMM probing forces would move the springs instead of making a definite assessment.”
Backed by intuitive and simple-to-operate software, the OGP CNC 300 machine purchased by Adwin utilizes a high-quality auto-calibrating camera and supports a combination of touch probes, micro probes and laser scanners. It is designed for use on the shop floor and, across a multitude of industry applications, collects detailed data quickly, precisely, reliably and automatically.
Working with more accurate and real-time statistics, from a single reference point, means tighter control of production processes, as any issues can be identified and remedied immediately.
Measurement Without An Operator
Mr Hayes said: “During the demo stage we realized that the OGP interface was more suited to our business as we produce a large range of parts, so set-up and program initialization needed to be much quicker than most other machines because of the vast array of products we’re making.
“We started to see the benefits within the first month. A lot of our parts, as we’re doing process inspection, were programmed up very quickly and then the machine runs the program in 30 seconds rather than the five minutes it took checking parts on a shadowgraph.
“Other than a major improvement on process inspection and the time saved on writing reports and producing first-off inspections, it’s also drastically improved the quality of the product we send to our customers. It’s completely eliminated any sort of inaccuracies.” states Hayes
For more information: www.ogpuk.com
