Solidworks Inspection Automatically Generates Balloon Drawings & Inspection Reports
Solidworks Inspection 2018 is a First Article Inspection (FAI) and in-process inspection software that streamlines and automates the creation of ballooned inspection drawings and inspection reports (AS9102, PPAP, etc.).
Solidworks Inspection consists of a stand-alone application and a SOLIDWORKS add-in that enables users to leverage their legacy data regardless of whether they have SOLIDWORKS files, PDFs, or TIFFs.
Solidworks Inspection is a simple and intuitive application that can reduce the time needed to create inspection documentation by up to 90 percent, and helps to virtually eliminate input errors, thus improving quality and reducing time-to-market.
The Solidworks Inspection Professional version extends capabilities further by giving users multiple ways to enter measured values directly into the project to help simplify part inspection. Each characteristic value can be entered manually, by using a digital caliper, or by importing coordinate measuring machine (CMM) results.
When working with a PDF or TIFF drawing, Solidworks Inspection can instruct Optical Character Recognition (OCR) to read and identify the nominal dimension, tolerances, and type of dimension (such as diametric or linear) helping to virtually eliminate manual input and reduce errors. It works with horizontal and vertical dimensions, split dimensions, notes, hole call-outs, finish GD&T symbols.
For more information: www.solidworks.com
Verisurf Expands European Presence
