Reverse Engineering Construction Machinery with Artec Eva and Geomagic Design X
Artec’s Gold Partner in Turkey Teknodizayn has successfully completed a project for replacing old parts of a construction machine with new ones, milled from 3D models that were generated with Artec Eva, a high-precision portable 3D scanner for large objects.
The task was commissioned by Assan ASP, a well-known international manufacturer and distributor of construction machinery spare parts. Normally it would take Assan ASP a couple of weeks to measure and draw these parts, in this case some of the elements were quite difficult to measure accurately with traditional methods.
After receiving a demonstration by Teknodizayn, Assan ASP managers concluded that it is significantly easier and much faster to work with Artec 3D scanning solutions and Geomagic reverse engineering software on cases like this.
The task was to duplicate two independent parts of a construction machine (drawbar & yoke assembly and circle assembly) for future use. The parts needed to be accurately manufactured from the data obtained during 3D scanning and then fitted to the same type of construction machine.
“As we know, Artec 3D scanners are the best to use in situations where there is a big part that needs to be scanned in a location where conditions are difficult. This was exactly this kind of situation,” says Ali Can Boysan, Sales & Technical Support Manager at Teknodizayn.
Ali had to scan on the premises of the manufacturing facility, wearing special safety equipment. He used the Artec Eva scanner along with the Artec battery pack as there was no immediate access to a mains power supply. “The freedom of movement with the Artec battery pack was a huge advantage,” says Ali.
The parts featured some shiny and metallic surfaces, so those areas needed to be sprayed before scanning.
“Artec Eva was the suitable scanner for this job as the parts were very big and the accuracy required was in the range of Artec Eva’s accuracy,” says Ali. “The scanning was pretty fast and easy considering that those were huge parts of around 3 meters.”
Each part took 30-40 minutes to scan in detail including top and bottom areas. “Those were very fast scan sessions,” says Ali. “No other scanner can measure such big parts this accurately and fast.”
Once done with the scanning, Ali transferred the data to his computer at the Teknodizayn office. Post-processing each part in Artec Studio 11 3D imaging software took around 4-5 hours. There were numerous scans from different angles on both top and bottom sides of the parts, which added up to a large amount of data. The data was processed manually. First the unnecessary parts of the scans were erased, and then the scans were aligned using the quick and simple point to point alignment algorithm. Global Registration with Texture and Geometry was applied, which resulted in a dense and accurate point cloud that needed to be meshed. The next step was Sharp Fusion with the best possible resolution, creating .stl mesh models ready for reverse engineering.
The files were exported to Geomagic Design X reverse engineering software. “This is no doubt the best, fastest and easiest program among its competitors,” says Ali. “Our reverse engineering specialist first auto-regioned the parts and then aligned them to coordinate planes. Later he parametrically drew the solid models accurately, feature by feature. After 7-8 hours of working on each part, the solid models were ready to be manufactured directly.”
The manufactured parts achieved the exact precision required. They were installed and tested on a working construction machine, proving to fit very well. Assan ASP were impressed with the results and bought an Artec Eva, Space Spider and Geomagic for SOLIDWORKS CAD bundle to improve their traditional workflow and use the technology in future R&D projects.
