RangeVision Launch Spectrum Three-in-One High-Resolution 3D Scanner
3D scanner manufacturer, RangeVision has launched its latest technology, a high-resolution scanner capable of shooting objects of all different sizes. The three-in-one scanner, named Spectrum, is equipped with 3.1 Mpix industrial colour cameras and maintains an accuracy up to 0.04mm.
Spectrum offers three scanning zones and three scanning modes which allows the capture images from 1cm up to 3m away. Spectrum can provide highly detailed scans of any type of object, from jewellery to large vehicles. RangeVision, located in Russia, believe the Spectrum is the perfect solution for companies that specialise in 3D scanning services, reverse engineering, product design or production of small or medium-sized objects.
The scanner’s three modes separate items into small, medium and large categories. Small objects, such as a ring, can be scanned at 1cm to 40cm distance, medium-sized objects can be scanned at between 30cm and 1 metre, while larger objects, such as a complete vehicle can be scanned at 60cm to 3 metre distance. Spectrum also includes an automatic turntable to enhance the 3D scan, as well as a travel case for easy transportation.
The 3D scanner housing was selected tobes manufactured a two-component polyurethane material due to its impact resistance, abrasion and heat resistance making it is an ideal material.
For more information: www.rangevision.com
