RangeVision Pro Structured Blue Light Scanner Launched
RangeVision PRO professional 3D scanners are capable of digitizing objects of different shapes and sizes simply by switching between four scanning zones. Using blue structured light technology RangeVision 3D scanners capture complex geometry with an accuracy of up to 0.018 mm and 3D resolution 0.03 mm.
Developers of RangeVision PRO focused on designing a simple easy-to-use 3D scanner that requires minimal setup time offering speed and simplicity with low user engagement during the scanning process. A robust housing reduces the impact of external flutter and prevents overheating during extended use periods. Switching between its four scanning zones is rapid with the user just fixing the cameras lenses in preset positions without need for adjusting the camera angles.
RangeVision PRO offers an optimal price/performance ratio.
No projector adjustment is necessary with brightness, contrast and other parameters pre-installed. The user simply selects the 3D scanner configuration depending on the desired result and size of the scanned object. Available options include automatic turntable and a protective travel case.
RangeVision PRO is supplied complete with RangeVision ScanCenter software developed for fast processing of scan results. RangeVision ScanCenter software optimizes the resulting 3D model with automated functions to align and merge 3D scans into a complete digital 3D model, without exporting to a separate post-processing software,  providing a high-precision STL 3D copy of the scanned object. Free software updates are included with the RangeVision PRO scanner.
For more information: www.rangevision.com
