Polyga Launches HDI Carbon Crossover 3D Scanner
Polyga Inc., a developer of professional 3D scanning and mesh processing technologies, has announced the launch of a new crossover structured-light 3D scanner, the HDI Carbon. This powerful system can easily adapt to different scanning requirements while still being lightweight and portable to take to off-site projects.
At the core of the HDI Carbon is its custom molded carbon fiber frame. It makes the entire system super flexible while being lightweight at just 1.9 kg (4.18 lbs). The HDI Carbon has a variable field of view. The 3D scanner empowers users to scan objects of different sizes–all in one system. The system has two camera mounting positions on the carbon fiber frame to adjust the scanner’s diagonal field of view from 225mm to 600mm.
“The HDI Carbon showcases the best features of the 3D scanning systems in the HDI product line,” says Thomas Tong, President of Polyga Inc. “At one end of the spectrum, we have the HDI Advance which is known for its flexible field of view. At the other end, the HDI Compact is ultra-slim and easy to take along for traveling. The HDI Carbon provides advantages from both systems into one convenient solution.”
Delivering Professional Results
HDI Carbon delivers industrial-grade 3D scanning results using two-megapixel industrial quality machine vision cameras. The system generates on average more than four million polygons per scan at an accuracy of up to 50 microns (0.0020″) for a 225mm diagonal field of view. The system uses a LED projector for a long life span. It emits minimal heat which reduces scan distortion for repeatable 3D scanning results.
Scan Wherever You Go
A performance driven 3D scanner shouldn’t be limited to only scanning in one location. For maximum portability, the scanner comes with its own travel case to take with you, wherever you need it. All the components fit nicely inside the case for added protection. It’s crushproof, watertight, and dustproof.
IP65 Blue Area Scanner Acquires High Resolution Images
The system comes with proprietary 3D scanning software, FlexScan3D, for 3D capture, advanced post-processing capabilities, and quality inspection tools.
For more information: www.polyga.com.
