Perceptron Introduces Green Laser Scanning Sensor For Shiny Parts
Perceptron has announced Helixevo its latest 3D scanning sensor for in-line and near-line applications.
Helixevo takes scanning to the next level, improving performance through faster measuring and increased overall system robustness. Inside the IP67 rated housing, Helixevo utilizes a green laser to measure the multitude of materials used in today’s manufacturing, such as chrome, aluminum, sheet metal, and painted surfaces. Its best-in-class scan acquisition provides accurate feature extraction along with the pristine scan quality required for form analysis. Helixevo also uses a single Power over Ethernet cable which reduces the number of auxiliary components required, and is designed for fast and accurate measurement on the plant floor.
Dave Watza, President and CEO, commented, “Helixevo is a significant evolution in our Helix sensor family, providing vastly improved point clouds and plant-hardened build quality. Helixevo provides the data our customers need for quick, real-time resolutions, whether the root cause of their quality challenge comes from their assembly or stamping process.”
Over the next several months, Perceptron will be installing Helixevo systems on the plant floors of three key customers.
For more information: www.perceptron.com
Polyga Launches HDI Carbon Crossover 3D Scanner
One thought on “Perceptron Introduces Green Laser Scanning Sensor For Shiny Parts
Comments are closed.
