Pentaxia Halves Production Time and Eliminates Rework with MSP PerfectPart
Advanced tooling and composite components manufacturer Pentaxia has transformed how it approaches the machining of complex components after introducing MSPโs PerfectPart suite of CNC metrology products into its process. The introduction generated impressive results for one project alone, reducing production time for a set of parts from 40 to 20 hours and eliminating a 100% concession rate, with 50 sets delivered without a single part requiring rework.
MSP PerfectPart was initially introduced during a challenging project involving the machining of composite components made from multiple materials, where variability and distortion made accurate setup difficult using conventional methods.
Previously, Pentaxia had relied on a manual setup process that required significant decision-making, along with manually shimming and clocking features on components, often taking multiple shifts to set up a single part.
โWe didnโt have a good way of checking our setup, and the process didnโt account for all six degrees of freedom,โ said Lucian Lazar, Lead Technical Engineer at Pentaxia. โI donโt think there was a single part that was set up 100% correctly โ each one had a concession raised against it.โ
Pentaxia also lacked visibility of machine performance, meaning any issues were only identified after machining had taken place.
โWe were essentially machining blind, which created a stressful environment,โ explained Lucian. โThese parts were worth tens of thousands of pounds. None of the operators wanted to take part in this project because the pressure and risk were so high.โ
Determined to make the project a success, Pentaxia invested in a new CMS machine and introduced MSPโs PerfectPart suite of products to address problems at different stages of the CNC machining process.
This included NC-Checker for assessing CNC machine performance and NC-PartLocator for automating the part alignment process.
NC-Checker has proven so valuable at identifying machine issues that no part is machined unless the machine has first been assessed using the software, even if that means running it multiple times a day.
Likewise, NC-PartLocator has transformed Pentaxiaโs part setup routine and removed many of the stressful decisions. โThe contrast between before and now is extraordinary,โ Lazar said. โWe can generate the alignment in a single operation and start machining almost immediately.โ
This faster setup procedure has reduced production time per set of parts by 50%, from 40 hours to 20 hours. The removal of manual error, combined with NC-Checkerโs machine performance assessment, has also enabled Pentaxia to eliminate concessions entirely.
While the technology was initially introduced as a โleap of faithโ to support a specific contract, its impact has extended far beyond the original requirement, influencing a broader machining strategy and fostering a more confident, controlled shopfloor culture.
โAll of the complex jobs go on the fondly named โMSP machineโ because thatโs the safest place for them,โ Lucian said. โThe most complex parts now have the fewest errors โ a total paradox compared to traditional manufacturing.โ
As a result, the cultural shift across the shopfloor has been significant. Lucian commented: โA complex project no longer has the fear factor and is seen as a positive challenge. The process is reliable and repeatable, and confidence across the shopfloor has soared.โ
Lucian concluded: โAt the end of the day, it is the natural progression for CNC manufacturing. We used to machine parts by hand, then 5-axis CNC machines were created. This is the logical next step. People donโt need to be setting up parts by hand anymore when MSP can do it automaticallyโ.
For more information: www.mspltd.com
