New Portable 3D Scanner Designed for Rapid Measurement
Smarttech 3D portable 1.3Mpix is the latest portable 3D scanner designed for rapid measurement and mobility. It features an extremely high accuracy of 0.06mm and an instant scanning time of no more than 0.2 seconds. The device retains all the convenience, as scanning measurements can be performed by either holding the scanner or placing on a tripod.
Mobility is provided by a battery pack and the convenience of use is ensured by a touch screen built into the scanner. Together with the computing unit, it allows not only single measurements scanning but also the possibility of combining scans by using geometry based alignment. Intuitive software guides the operator through the entire scanning process, so metrology expertise is not required.
The measurement method used by the Smarttech 3D portable is based on harmless white structured light. There is no laser or physical contact involved during the scanning making the device 100% safe.
Factory calibration of the Smarttech 3D portable is certified by the manufacturer in accordance with the German VDI/VDE 2634 standard. The measurement accuracy can also be confirmed with a certificate by an independent certified measurement laboratory. The official launch of the new Smarttech 3D portable scanner will take place at Hannover Exhibition, Germany 24 and 28 April.
A new version of Smarttech3Dmeasure v2017 software allows to work with over  200 million points at a comfortable 5 frames per second. In addition, the ability to select an automated measurement in STL triangles grid minimizes scanner’s operator involvement in post-processing. The new Smarttech3Dmeasure v2017 control module provides the ability to create a complete 3D model and analyze its cross-section.
For more information: www.smarttech3dscanner.com
Leica BLK3D Creates Images Containing Precise 3D Measurements
