Diondo Compact Entry-Level CT System With Premium Equipment
Reliability and precision are important in industrial production, not only in manufacturing, research and development, but also in quality management. With the d1, Diondo GmbH is launching a new, compact CT system, which leaves nothing to be desired with regard to accuracy, speed, ease of use and flexibility.
The new computed tomography d1 system not only optimally meets the stringent requirements of metrology, but also the high demands of non-destructive material testing with great precision. Diondo consciously focuses on premium component parts. Instead of the metal manipulator usually used in this market sector, the system rests on a solid granite base. The inherent stiffness and temperature stability guarantee perfect results even after many years of intensive use.
Furthermore, the axes are equipped with glass scales from the company Heidenhain, a feature that is normally only provided by CT systems in higher price brackets. The concept works: the highest accuracy according to the VDI / VDE guideline 2630 is consistently achieved.
Another highlight of the Diondo d1 is the high-contrast 3K detector. The combination of a narrow pixel grid and a particularly large active area offers the user several advantages including providing an extremely high resolution when examining small objects and also offering the imaging of large test pieces “in one shot,” without having to capture them in several partial scans, which can be very time-consuming. The diameter of the part under inspection can be up to 300 mm, with a maximum height of 500 mm. The unit is approved for unit weights up to 20 kg.
The Diondo d1 is ideally suited both for non-destructive testing on metal and composite components as well as for high precision metrology on plastic. The d1 system is ideally suited both for industrial production as well as for service providers, laboratories, R & D facilities and research institutes.
The machine will be exhibited at the Contro Expo Hall 3 Booth 3114 in May.
Using X-ray Computed Tomography for Dimensional Metrology
For more information: www.diondo.com
