Blue Light Laser Sensor Measures Reflective and Shiny Surfaces With Speed and Precision
Micro Epsilon’s new optoNCDT 2300-2DR sensor uses blue laser light and is uniquely compact and specifically designed for displacement and distance measurements on directly reflecting surfaces. On reflective and shiny surfaces, the sensor operates at high speed and provides maximum precision in the nanometer range.
The laser sensor is especially suitable for reflective and shiny targets and as an example can be used in thickness measurements of flat glass, distance measurements on annealed glass and assembly monitoring of extremely small parts. The measuring rate can be set up to 49kHz making the sensor ideally suitable for process monitoring tasks. While operating with the Advanced Real-Time-Surface-Compensation (A-RTSC), the sensor enables a precise real-time surface compensation of different surface types. Data output is via Ethernet, RS422 or EtherCAT. When operated with the CSP2008 universal controller, an analog output is available with measurement values of material thickness and width synchronously acquired and evaluated.
The sensor is based on a parallel installation to the measurement object. The blue laser light is directly reflected onto the receiving optics by the measurement object. Unlike red laser light, the blue laser light does not penetrate the measurement object. A sharp point is projected onto the surface, which enables a stable signal on the receiver element. The extremely small laser spot size allows the sensor to detect very small objects. In addition to its high precision sensor technology, the size of the sensor makes the new optoNCDT 2300-2DR unique with its entire electronics is integrated in the compact housing.
The optoNCDT 2300-2DR sensor is based on the principle of optical triangulation. A visible, modulated light spot is projected onto the target surface. The receiving optics produces the direct proportion of the light spot, in dependency of the distance, onto a CCD element with spatial resolution. A digital signal processer in the sensor calculates the distances between the light spot on the target and the sensor from the output signal of the CCD element. The distance value is linearized and output via an analog or digital interface.
SHINING 3D Releases Multi-Functional 3D Scanner
For more information: www.micro-epsilon.com
