Automatic Volumetric Compensation of Coordinate Measurement Machines System Launches
Etalon AG will launch its new interferometer based measurement system LineCal during the upcoming Control Exhibition. The LineCal system is addressed to manufacturers of compact multi-sensor measurement systems, coordinate measurement machines and machine tools who want to calibrate their machines fast and very precisely prior to customer delivery.
In one setup LineCal records all systematic geometry deviations (deviation in position, straightness, pitch, yaw, and roll of all three axes and squareness) based on the laser wavelength and generates the volumetric compensation data directly in the specific format of the machine controller. Intelligent routines make the setup easy; the measurement routine for the complete volumetric compensation is being carried out automatically in 40 to 60 minutes. The effort for machine calibration is reduced considerably.
At the same time, the Etalon system reaches extraordinary high precision in the determination of error : even deviation parameters which are very difficult to measure, i.e. the roll of the axis, can be determined extremely precisely with the Etalon patented principle of measurement.
LineCal is based on the approved interferometric principle of measurement which Etalon already makes use of in its other measurement systems. To save space and weight, Etalon abandoned the tracking of the measuring beams; instead a simple but specially tailored fixture with a large number of pre-installed interferometric measurement lines is being used for each machine type.
Geometric image of the machine
The LineCal measuring lines are arranged in such a way that the automatic measurement reflects a highly precise geometric image of the machine. The results of the analysis can be used directly for the structure error compensation. “A lot of development work has been spent on the configuration of the static measurement lines and the mathematical methods,“ reports Dr. Schwenke, CEO of Etalon AG. “Together with our multi-channel-laser interferometer we can realize ideal configurations for almost all machine types.”
To carry out a measurement, a tailor-made ficture is placed on the machine. The adjustment of the machine positions is supported by the software. During the measurements, the machine follows automatically and sequentially the pre-installed measurement lines and records the deviations between the measurement system of the machine and the interferometric measurement channels. From this data, the Etalon software calculates the deviations of all machine axis.
Optical Measurements Migrating Process Control to Process Knowledge
 “LineCal pays off mainly if the same machine type has to be calibrated several times. This makes the system especially useful for equipment manufacturers. The demand in this segment is high because calibration is a significant cost factor in the production of precision machines,” adds Dr. Schwenke. “LineCal profits from Etalon´s knowhow in the field of laser measurement technology, calibration and machine interfaces. It increases the application of our base technology for a new class of machines and drastically decreases the time compared to other existing methods.”
The Etalon LineCal system can be viewed in Control Exhibition Hall 4 Booth 4426
For more information: www.etalon-ag.com
