Additive Manufacturer FIT Adds Diondo Computer Tomography System
FIT has added a diondo d2 state-of-the-art computer tomography (CT) system to its growing inventory of advanced manufacturing technology. A pioneer in industrial additive manufacturing, FIT is now also the first AM manufacturer to establish an in-house QA department.
Having in-house CT scanning allows for high-precision measuring and visualization of inner and outer structures, providing customers with an even greater level of confidence in the AM parts produced by FIT.
FIT Goup – A Trendsetting Pioneer in Additive Manufacturing
The strategic use of CT in Additive Manufacturing is to increase product quality and to optimize the production processes. Due to this non-contact and non-destructive measurement and analysis of inner structures, FIT is able to increase process stability for FIT’s manufacturing systems – more than 40, after all. The diondo d2 CT system allows FIT to identify or verify the existence of pores, cavities, fissures, form deflection, displacement, shape distortion etc. Evaluations such as design vs. part comparison or analysis of wall thickness are visualized in color and serve as proof of specified product requirements.
Additional Benefits of Advanced Metrology
Real applications for additive manufactured metal parts are broad and demanding. To ensure adherence to technical part requirements, FIT has added this reliable technology for efficient and high quality component analysis – from the interior to the exterior of the part. As an example, color analysis can illustrate geometric flaws when comparing the scan data of the produced part to the original CAD model, and dimensional tolerances can be reliably verified even for complex and bionic structures. “The adoption of in-house CT scanning allows for high precision quality control in-line with our manufacturing processes, increasing efficiency and reducing lead time for our customers. At the same time, production processes can be improved continuously and significantly through this same data evaluation”, explains Carl Fruth, Founder and CEO of FIT.
Scatter Correction for Industrial Cone-Beam Computed Tomography
Technical Highlights
Optimal results of cross sectional views are achieved using high resolution (up to 5 μm) at a maximum acceleration voltage of 240kV. A 3K detector provides a 1/3 higher resolution when compared to standard detectors. 3D analysis is compliant to VDI 2630. The diondo d2 CT scanner is equipped with a reflection target of 300 Watt power. Maximum size of the parts is Ø 520 mm x 700 mm.
FIT employs approx. 230 people, most of them at the company’s headquarters in Lupburg, Germany. The FIT Group operates two further subsidiaries near Hamburg, Germany, and in Boston, MA, USA.
For more information: www.diondo.com
